Super PO`D
Super PO`D
Super PO`D
Larry in NW Ohio
>( >( If the manufacturers of power tools want to really improve their product in sum way the only thing that they would have to do is to make the dust outlet the same size as the hoses on the vac`s. Either 2 1/2" or 1 1/4" or what ever they call them. I just bought a Bosch power hand planer and it has some kind of really odd ball outlet so that I can`t hook it to my vac anyway possible yet. Even if I could, that`s not the point. It should be made to hook up to a standered size. Since the vac hoses are PRETTY much the same size that is what they should make them for. From now on if I can`t hook up to my vac, I don`t care how great it is I`m not going to but it. Well I guess I`m off to spend a half a day making something to hook up my vac. I feel a little better. Larry
Re: Super PO`D
Re: Super PO`D
Dale Penkala
I know what you mean Larry! I had the same thing with one of my disc/belt combo sanders, but I went down to Woodcraft and got a universal hose adapter. It has several tapered steps down the adapter that took care of my problem. Just keep cutting the tapered adapter to fit your connection.
Its just a thought. :)
Dale
Mid-Michigan
Re: Super PO`D
Re: Super PO`D
Larry in NW Ohio
Dale thanks for the thought, but I did think about that long ago when I got my first tool that didn`t fit. But really why should have to buy something else to fit the vac`s when they only have two sizes and the manufacturers know that. Be sides I usually come up with something to work. I took the dust bag out of the box of the Bosch and took the dust connector apart and cut it to fit my vac, with a radiator hose. I know, I know I`m just being childish. Larry
Re: Super PO`D
As always, duct tape is your friend.
Re: Super PO`D
(Message Deleted by Poster)
Re: Super PO`D
Re: Super PO`D
Larry in NW Ohio
Galen Good Point, but it is still irritating. Larry
Re: Super PO`D
Moses Yoder
Re: Make a mess
Moses Yoder
The power plane is designed to make a real mess, then afterwards you go though with a wide push broom and sweep it up. You may have been better off spending your money on a Lee Valley bench plane. Maybe not though, there's no dust port on those either. Have to go talk to Rob Lee.
Re: Super PO`D
Re: Super PO`D
Dave Bair, Eaton Rapids, MI
All my Porter Cable and Bosch tools fit my Fein vac's hose perfectly. My new PC 390 sander's vac fitting accepts two sizes of hose, so maybe someone is listening.
Re: Super PO`D
Re: Super PO`D
Nick Tuzzolino
Galen has the right idea. Good thing I have a lathe. Between Grizzly, etc, I have had to adapt fittings mostly out of PVC(if lucky, to get a close fitting). It is indeed frustrating to have to do this. Goodluck.
Re: Super PO`D
Re: Super PO`D
Larry in NW Ohio
Nick As I said in my one post, I did get it to work. I took the dust bag and took the plastic connector apart and the outside part of it kind of fit, after I cut part of it off. I got some radiator hose years ago that fit the 2" connector, so that slid right on the bag connector. I won again. Larry
