A question on plants (OT)
Larry in NW Ohio
I have a question that going to sound pretty wierd, even for me. When watering flowersnand such things outside, does it do any good to water the whole plant like the leaves and roots instead maybe just trying to water just the roots. In others do the leaves soak up some of the water. It seems to me I heard a long time ago to water the leaves also when watering the plant, not that it makes any difference. Thanks. Larry
Re: A question on plants (OT)
Stuart Johnson
Larry, With the current drought I need to water the pots daily and deep water those planted in the beds every other day. I have my own theory and do wash the whole plant maybe every 3rd watering. My reasoning is the plants need to absorb oxygen and carbon dioxide through their leaves and dust blocks some of the absorption. So, washing off the dust has to help and can't hurt. The one exception might be roses but I still wash them once a week. They are just hanging on and surviving.
John Veerkamp
Stuart has it right. Plants take in water thru the roots and transpire thru the leaves. Dirt and polution on the leaves can interfere with the cycle so washing the leaves periodically helps. Frequency depends on local conditions and even specific locations within your yard.
Water on leaves
Tom Dunlap
Right...wash the leaves/water the roots.
If you're going to follow this be sure to do it at a time of day when the leaves can dry out. If not, there are all sorts of Rougish Fungiis lurking around wanting to chow down on wet leaves. Powdery mildew is one.
Re: Water on leaves
FredD
I havwe over the years read Expert Gardner's advice on watering Tomato plants and they all cautioned against getting Water on the plant and fruit.
So.... my question is how come Rain wouldn't damage them the same as water from a hose?
BTW I all of the Garden at the same time and have more Tomatoes then I can give away nearly every year.
FredD
Re: Water on leaves
Stuart Johnson
Fred, the same thing applies to roses - water the roots not the leaves. It has something to do with the water splashing up on the leaves and causing the spread of some fungus or something. The only difference between watering with a sprinkler and rain that I can think of is we usually water when it's sunny and it's cloudy when it rains.
