Newbie doing wood inlay
Shannon Burch
I'm working on a laser-cut inlay cribbage board design. The laser cuts away a decent amount of material; I was wondering, if I stain and finish with polyurethane (minwax fast-drying) will it fill in those laser cut lines so I have a smooth surface? If yes, will it will in the peg holes too and what do I do to prevent that? If not, is there a good way to fill the laser lines in? See the three pix at the site linked for reference. I am very new to woodworking so any advice is appreciated, no matter how obvious you think it is. :)
Re: Newbie doing wood inlay
Larry in NW Ohio
Shannon Welcome to WC, sorry I don`t have any advice for you as I`m not very good at woodworking let alone finishing. I just wanted to welcome you here and I hope you come back often, because this is the most friendly place and you can get almost any question answered that you need. So do hurry back. Larry
Jesse Cloud
I can think of two ways to go about this.
The first is the easier way that requires no particular skill. Go to home depot or somewhere and buy a can of wood filler. This stuff spreads with a putty knife and will fill your holes. I would tape over the cribbage holes to protect them. You will probably have to do two applications of the filler as it will shrink somewhat when it dries. You could also mix in a dye to color the filler before you use it. After it is dry, sand it flush with the rest of the board and put on a topcoat of poly or whatever.
The second way is true inlay. You would buy a nicely colored wood with straight grain (Holly is traditional, but expensive and not stocked by most lumber yards). You would cut off "strings" of the wood with a knife or handplane, glue them into the laser holes and then plane flush. This would be the most handsome solution, but it would take a lot of work and there is a good chance you might damage the cribbage board with the plane.
Hope this helps and welcome to WC!
