Motor going wrong way(OT)
Larry in NW OHIO
A while back I post for help to hook up a samll to speed motor to a High-low switch. I got it hooked up and workes well but in one of the speeds it goes in reverse. Before some suggest it yes the switch is two speed. It was hooked up to a two speed motor awhile back. Also there is nothing on the scymatic on the motor about being a reverse in it. So I suppose it could only be in the switch? Before I go tearing into it I want to check with someone who knows more. I did notice on the switch that there is a jumper wire from one connection to another. Thank you. Larry
