Shop heater
Larry in NW OHIO
My neighbors gas heater is broke. It`s called a blue flame vent free gas heater. the control valve got broke. Does anyone know where I can get parts for this. Thank You. Larry
Shop heater
Larry in NW OHIO
Re: Shop heater
Lynn Reedy
If it is a propane heater then the propane supplier may stock
a valve. Big city dealers probably won't but most rual dealers have
always good supply of parts. Hope this helps.
Re: Shop heater
Larry in NW OHIO
Thanks that`s a begining. Larry
Re: Shop heater *LINK*
Kneale Brownson
BlueFlame used to be part of Comfort Glow heaters, I think. Their website directs you to Master Distributors for parts.
Heater Parts
Re: Shop heater
Larry in NW OHIO
Thanks Kneale, but I beat you to it. I got their web site from somewhere, I think from Desa. They don`t seem to have the control. I`ve tried a couple of time, but it says that they do not have that part anymore. Unless I`m doing something wrong. Larry
Re: Shop heater
Larry Clinton at Frankfort, (Central) Indiana
As far as I know no manufacturer of heaters, furnaces etc builds their own control valve. Any Heating/AC supplier can get you a replacement valve. The criteria for the replacement includes the type of pilot sensing (thermocouple/power pile etc.), standing pilot or igniter etc., whether it is a single or two stage valve, physical size, port size and operating voltage. I did service many different type heating units including furnaces, hanging heaters, closed combustion etc. over the years. I have even converted power pile type to standard thermocouple, (requires adding a transformer and thermostat). Another thing you may try is to take the number from the gas valve and do a "goggle" search, you may find the exact valve available or a replacement number - most likely it is a Honeywell valve, but there are a few other manufactures that did/so produce valves. Here is a link to one valve supplier - http://www.famousdiscountwarehouse.com/honeywell1.html (haven't used them - just one I Goggled).
