L&V's coffee table (PICS) *LINK*
Hikmet C. Sakman Victoria, BC CDN
I have had these two sheets of spectacular maple burl veneers for around 12 years or more. I knew they were destined to be a table top. Finally the opportunity came along a few months ago, when my referred clients asked for a dramatic and large coffee table.
When bookmatched, these maple veneers looked like a topographic aerial photograph of a dry landscape. Whoever seen it, just mesmerized by it. So the credit is due to the wood, although I had to do some painstaking veneer work to get it all down flat, since it was badly buckled due to the nature of its grain. Also, bordering the maple center with Macassar ebony without any cross inlay, demanded precision jointing and I am glad it turned out flawless.
Legs are attached to 1 inch thick inner frame, then it is screwed to the bottom of the table top. It is a quiet heavy table, 4 legs alone weigh a ton.
My external flash did not work, so I'll take better pictures later on though these ones will give your "trained eye" some idea about the grain and construction details.
I must admit, it turned out to be way more work than I anticipated but at the end I think it was worth it.
It is 42"x 47" and 16" high. I didn't want to cut off and waste the maple veneer, so that's why it is not square. I sanded up to 400G and my own mixture of varnish is hand applied. Yes it is a satin sheen, and turned out very well. Usually I like larger surfaces sprayed, but I am glad I did not.
Thanks for viewing,
Chico...
Sakman Fine Woodworks
Re: L&V's coffee table (PICS) *LINK*
Moses Yoder
Moses Yoder
Did you use a vacuum press to put the veneer down, or what? It looks great.
Don Orr
That is over-the-top gorgeous!
FredD
Thanks for showing Chico, as usual very well done , hope you charged enough :D
FredD
Yonak
Exhilarating .. really striking ! I especially like those legs. They're stupendous.
Thanks Moses, yes I did used the vacuum veneer press which is pictured in the "LEGS" post down below, while pressing the segments of the legs.
Thanks,
Chico...
Aside from the fact that this is spectacular
Bruce, a MN Galoot
I really DO hope you charged enough. I scarcely know where to begin with my own meager work, and wouldn't have the foggiest notion of how to price a masterpiece.
Nakashima is often quoted as saying there's one perfect use for each magnificent piece of wood. You surely seem to have found it in that top veneer. Uffda!!
Nick Tuzzolino
Hi Chico:
I'm trying to picture you working on that in your shop.
A doing in itself. Thanks for sharing. Absolutely gorgeous!!.
Nick
Dale Penkala
Absolutly incredible! Beautiful work SIR!
Dale
Very nice, Chico!
You have a way of making strong contrasts sing. The composition is really unique and daring, and, as usual, you've pulled it off beautifully. I wouldn't have expected less.
Thanks for posting. I'll be interested to see the table in its intended setting. It's going to light up any room it's in.
Cheers,
Gorgeous, Chico
George Colonel's Workshop-Havertown PA
Well my friend,
You've really done it again! that top is mesmerizing, and all that flattening work must have been a real challange. The outcome, when you do it, never seems in doubt. And the legs! Perfect in every respect, and they remind me of my wife and her twin sister :)
George
Re A request
Larry in NW OHIO
I just can not imagine something like that, let alone something that beautiful being able to be made. You have the most outstanding talent for woodworking. I would give almost anything just to watch you make something like that from begining to end. That would be a dream of a lifetime fulfilled. To watch a master craftsman build something that I could never even think of. Thank You for sharing with us. Could you post a picture of the underside of the top? I`m curious what you put there. Larry
Jorge Castañeda
Good work as usual.
Thanks for sharing it
