Tool Chest
Tool Chest
Tool Chest
Todd Nebel
Let me begin by saying I almost never do any woodworking during the summer. For one it's too hot in my basement workshop and two I much perfer riding the Harley when the weather is good. And there you have it, the weather has not been cooperative this summer. Another factor was I came across a little curly cherry and was itching to use it. So, on a rainy day I was flipping through some older issues of FWW and saw this article from Chris Gochnour - Heirloom Tool Chest. It was a perfect project to take my time and practice my hand tool skills. Other than ripping (bandsaw) the boards to near width and planing (power planer) to near thickness, everything was by hand. Finish preparation was from smoothing plane or card scraper. The only use of sandpaper was to soften the edges.
I installed the hardware today and loaded it up with a bunch of stuff. I've never worked from a tool chest before. Up until about a year ago I was primarily a power tool woodworker. Hand tools were only used to fine tune my joinery. So, it will take a few hand tool projects to work out what I will keep in the tool chest and what will be returned to the wall cabinet above the bench and in the cabinet drawers here and there in the shop. Hopefully this will be itself a useful tool in the shop.
Thanks,
Todd
Re: Tool Chest
You're gonna use that thang?!
Bruce, a MN Galoot
That's a seriously nice tool box. Very good work, Todd!!
Re: Tool Chest
impressive
Jerry Gibbs
Re: Tool Chest
Re: You're gonna use that thang?!
larry in Memphis,Tenn
Absolutly to nice to put sharp tools in and scrtch all up. Send it to me and I`ll put it on a coffee table in the front window. Do you have an idea when you can have that done? Really great job. Larry
Re: Tool Chest
Awesome piece of wood! Questions
Bill Tindall
Please explain the lid. Is the panel applied to the top of the frame? What are the tools that look like screw drivers with curly handles? You made them?
Too nice to live in the my shop. It would find a home at the foot of a bed and serve a trunk function.
Re: Tool Chest
Re: Awesome piece of wood! Questions
Todd Nebel
Thanks Bill!
The lid's frame is made with through mortise-and-tenons. I have a powermatic mortiser that I absolutly love. On this project I forced myself to chop these by hand. I was amazed at how straight and clean the mortises were. I bought a new mallet (shown in the bottom of the case) that also surprised me at how much better it was to strick a chisel with a flat face as to rounded. But, your question was on the panel. On the inside of the stiles and rails is a groove. The panel also has a groove all the way around it. The panel's groove is sized to fit into the groove of the lid frame. This raises the panel above on the top and recesses on the bottom. The panel is sized to expand and contract with the humidity changes. I misspoke earlier, this was one place where I went to the table saw - to cut the grooves. I cleaned up the groove bottoms with a router plane afterwords. I have a plow plane on the tool wish list. After the lid frame and panel was glued up and squared and sized to the case I applied the moldings around the lid.
Those are screw drivers. They are Lie-Nielsen screw drivers designed to fit the different size and types of screws on their planes and saws. My tool building skills are lacking. I've turned a couple socket chisel handles and a mallet, and made a beading scratch blade for an old Stanley No. 66 I bought at a flea market.
Todd
Re: Tool Chest
Re: Tool Chest
Jim Dillon
Todd,
Beautiful wood, chest, and execution! I'm jealous of your growing hand tool skills as mine are still pretty dismal, mainly because of the lack of practice. At least that is what I think is holding me back, but it could be lack of talent as well :| . Thanks for getting back to us with some pictures. Love that T&T finish :) .
Jim
Re: Tool Chest
WOW ! . . .
steve mackay
And ain't nuth'n like "move'n into" a new one is there ? Especialy when YOU made it !
Re: Tool Chest
Re: Tool Chest
Todd Nebel
Hi Jim,
I'm sure it's just lack of practice. I've been reading more lately about hand tool furniture building and how accurate and in most cases faster some tasks are. It amazes me how true these statements are once you get some practice. It's the finishing process that gives me the most heartache. Thanks for your help with the T&T. I decided it was finally dry enough to gently put the chest to use. Hopefully one heavy coat will be enough for now. My plan is to let the chest rest the remainder of the summer in the shop. I have nothing else planned to build in the shop right now. Then around September I'll go for the second coat of T&T and follow with wax. Show be 100% dried and cured by then.
Todd
Re: Tool Chest
Re: Tool Chest
I'm not sure I have tools worthy of a box like that. It's a real beauty. Thanks for letting us see it.
Tom
Re: Tool Chest
Re: Tool Chest
Jim Dillon
Todd,
Sounds like a good summer plan. Regarding T&T, here is a personal anecdote. Ten years or so ago, I built a bathroom vanity with two drawers - all finished with multiple coats of T&T. The drawer sides were QS oak. Nonetheless, after a year they had expanded enough to no longer slide easily (at the time, the house did not have AC). I decided that the easiest way to correct things was to sand the sides a bit. I was really surprised how durable the T&T finish had become. I had to get quite aggressive with the sanding in order to remove the finish and a bit of wood. So, I hope you will have the same luck with your chest finish.
Jim
Re: Tool Chest
Re: Tool Chest
George Colonel's Workshop-Havertown PA
Good Morning Tod,
Your hand skills are impressive. I admore your patience also. The net result is a box better than than any of the fine tools it contains. My reaction to the actual box is identical to Bill's: too nice to be in my shop. I would display it elsewhere. A gorgeous piece(s) of cherry, BTW.
George
Re: Tool Chest
Exquisite
Yonak
It looks like there are three depth levels and two sliding trays. Is that right or are my eyes failing me ? Well-thought-out design.
Re: Tool Chest
Looks fantastic!
John in NM
Re: Tool Chest
Re: Exquisite
Todd Nebel
Yes, that is correct. The bottom tray needed to be high enough in the case to clear the tallest plane. I went back and forth on the height of the two trays and settled on the same height as I wasn't and still am not sure what tools will end up where. The height of the trays needed to be at least high enough to hold the block planes sitting on their soles and the small router plane.
Re: Tool Chest
Something Missing
Where's the satin silk lining? Every jewelry box is supposed to have silk lining. :D
Impressive piece, Todd. Be proud.
Re: Tool Chest
That made me laugh out loud, thanks
Todd Nebel
Re: Tool Chest
Re:Very fine woodworking Todd.
The chest is impressive both in the workmanship and the wood - certainly looks to nice to be used in my workshop.
Re: Tool Chest
Gorgeous! Beautiful!
Joanne in Point Pleasant, PA
Wish it was here!
