working with purpleheart wood
Rick Snyder
Hello,
What has been your experience, working with purpleheart and what's the best finish to use? I've been asked to build a picture fame (2ftx2ft) out of this wood. Thanks in advance for the info.
Thank You,
Rick
Re: working with purpleheart wood
Robin Corell in Atascadero CA
due to a relativey high resin content it tends to burn easily with router bits or saw blades. it machines and cuts easily enough just know that it burns easily. I sand it to 320 then polish with #0000 steel wool and finish with General's HP poly. I have used oil finishes and lacquer on purple heart and they all look ok, for a while. The problem with purple heart is that it continues to react with the oxygen in the air and over time it will turn a muddy brown. The General HP is a waterbased finish with a UV inhibiter and I have had much better long term color using it.
Forgot to mention that after you are done with the project let it sit unfinished in the shop for a couple of days to develope a nice deep purple color before you apply a finish.
Robin
craigd
craigd
I have two different types of purpleheart, one very straight grained and brownish purple, a dream to work (hand tools or other). The other is a dark purple with mondo interlocked grain, very pretty, very very difficult to work with hand tools, I use carbide.
For finish, I used tung oil (the real stuff) + poly varnish mix which gave me a very nice deep burgundy luster on the brownish wood. BLO + poly has also worked well.
Another thought about finishing - try a finish that has UV protectors incorporated in the finish. It slows down the "browning".
