We value your privacy.
With water flowing the water pressure is maintained at the pressure regulator setting of 50 psi. Then with water flow stopped, the pressure downstream of the regulator slowly creeps up to source pressure, 100psi. Does this symptom mean I have a faulty regulator and replacing it will cure the problem?
The presure regulator I have is rebuildable and does need periodic checking. I have to rebuild it every other year, but I also have rather hard water. My upstream presure is 150psi so I have to have the regulator imidiately after the meter at the street.
here is a link to the regulator I have and there is a link to repair kits. Check to see if the regulator you have has pepair kits availablle and pick one up.
When I first installed my regulator I didn't know it was something that needed periodic maintainance so I buried it. The forst time I serviced it I put one of those plastic serice wells around it to make it easier to get to (not that anything about plumbing is easy)
If you have standard city water through a street meter and regulator and then supply line to the house , I would suspect a pinhole leak in the supply line especially if it's twenty years or older and Iron.
Try shutting off the water at the meter and see if the pressure to the house drops to zero.
If it does , call a Plumber , it will be easier on your back
The store where I bought my regulator stocks the repair kits. There is a "where to buy" button on the link in my first post, maybe that will point you in the right direction.
