We value your privacy.
I've decided to "bite the bullet" on a Jet 1000B AFS. I will be hanging it from the ceiling.
I can go with chain or 1/8" steel cable. (or 1/16" steel cable for that matter). I was thinking 1/8" steel cable as it is thin, flexible and I can easily make sure that the unit is level. I often use it in rigging things in the theatre. It also is inexpensive. Any reason to reconsider my notion and go with chain instead?
My old shop had exposed rafters and I hung my air filter with chain. I hung it level in the summer but in the winter I adjusted it out of level so the exhaust was aimed up to bounce off the roof and circullate the warm air back down to the work space.
JL, I don't see where it matters. Either material would work. I used chain on my homemade unit but since you're familiar with using the cable and it costs less, why not go with it?
My JDS 750 is suspended close to the ceiling from screw hooks into the rafters thru mounting rings in the unit's top. Seems to have worked fine for the several years I've had air filtration.
Here is some info and general rules based on Nagyszalanczy's "Workshop Dust Control" and some of my own experiences and thoughts.
The two most important criteria for an air cleaner are the CFM and the filters. You want a CFM factor that will clean the size of your shop and a filter that removes the particle size that you are concerned about.
To determine the size or required air flow, use this formula: Volume of your shop (Length x width x Height) times Number of air changes per hour (typically 6 - divided by 60. This will give you an answer in Cubic Feet per Minute which is how air cleaners are measured. MOST AIR CLEANER MANUFACTURERS RATE THE CFM OF THE FAN ONLY, but there are losses due to the filters. If you are building your own or if the air cleaner you are purchasing rates only the fan, figure you will lose about 25 - 40% for filtering losses.
As important as the air cleaner size is how and where you mount it. Try to mount at about 8-10 feet above the floor (no lower than 6'or 2/3 of the floor to ceiling distance if less than 8' ceiling). Mount along the longest wall so the intake is approximately 1/3 the distance from the shorter wall. Mount no further than 4-6 inches from the wall.
The exhaust is the largest determiner of the circulation pattern. You are trying to encourage circulation parallel to the floor/ceiling so ceiling mounting is not recommended. Use a smoke stick (or a cigar) to observe and maximize circulation. Use a secondary fan to direct air to the intake if necessary. Also, consider that a standard 24" floor fan moves a lot of air and, in some shops, just positioning it in a doorway with a window or other door open can accomplish as much or more than an air cleaner. It's all in the circulation patterns.
The exhaust is the clean air so that is where you want to position yourself. Do not place the air cleaner over the a dust producer. That will guarantee that the operator will be in direct line between the dust producer and the air cleaner. The operator wants to be in the clean air stream. If the dust has to pass your nose to get to the air cleaner, you get no benefits. If you have an odd shaped shop, two smaller units may be better than one large one.
DO NOT RELY ON A AIR CLEANER TO ACT AS A DUST COLLECTOR. The purpose of and air cleaner is to keep airborne dust in suspension and reduce airborne dust as quickly as possible AFTER THE DUST PRODUCER HAS BEEN TURNED OFF.
Finally, if you are looking for health benefits, you will not find any air cleaner manufacturer that makes health claims because there are few health benefits. CATCHING DUST AT IT'S SOURCE IS THE BEST LONG TERM GOAL. Rick Peters', author of "Controlling Dust in the Workshop", makes the point that spending your money getting the dust at its source is a better investment than trying to capture it after it is already airborne. If the dust is in the air, it's going to be in your nose and lungs too. Robert Witter of Oneida Air Systems has noted that "overhead cleaners can only lower ambient dust levels AFTER THE SOURCE OF EMISSIONS IS SHUT DOWN, and they take several hours to do this.
I used chain and "S" hooks. Simple to count the links so you're level (or at least parallel to the ceiling) and no fussing with swedge clamps, etc. Comes down easily as well.
My shop is roughly 4000 cubic feet ((18 x 25 x 8 = 3600)+ (7 x 7 x 8= 392)).
The Jet 1000B is capable (w/o the filter of 1044 CFM. So figure with the filter, maybe 700-800 CFM. I believe that it will be able to handle it.
My shop is shown below.
I can't have it on the south wall as I have upper cabinets on that wall. I can't have it on the west wall as I have lumber storage to the ceiling on that wall. This gives me a choice of putting the AFS on the north wall near where I have my lathe or the east wall above my workbench (the large rectangle).
