Holding glass in with just silicone
Terry Alexander
Hi guys and gals...been a little out of commission because of lots of reasons.....latest one was that my trusty laptop.....after too many years of service.....finally bit the dust and it took me a while to get all my "stuff" back just the way I like it.
NEWay...I'm back and I return seeking knowledge (which you all have :-)
I am installing glass in some kitchen cabinet doors. The glass does not fit in a dado or groove, yet it sits in a rabbet in the back...making the back side of the glass flush with the back side of the cabinet door. rabbet is 3/16
deep and 1/2" wide.
Q: Can I simply put a bead of silicone in the rabbet to hold the doors or will I need some kind of turnbuckle? Maxim size of a glass pane is about 15" x 12".
As always....thanks in advance for your valued expert opinions.
Terry Alexander in West Texas
Re: Holding glass in with just silicone
Pat Evans
There might be some adhesive for that purpose, but I wouldn't trust it without some kind of clip holding the glass in.
No *LINK*
You can "bed" the glass in a silicone bead to stop any rattle, but you'll still need some kind of retainer to hold the glass in the rabbet. You can make up a molding frame of use one of a variety of clips, such as the link, even if you have to modify them.
Glass Retainer
Larry in NW OHIO
Terry I built a china cabinent years ago, which has 3 fair sized glass doors in it. I siliconed them in and have had no trouble with them at all. But the only thing if the glass would get broke, you would have a hard time getting all the glass out. That stuff is like gule with wood. If you want to use some kind of holder to hold them in, I would suggest Custom "Service Hardware" that advertizes here. I have ordered quite a few things from them and really like them. I think they have some of the better priceing. Good Luck with your project. Larry
Moses Yoder
Moses Yoder
I have held glass in with just silicone on kitchens that were sold for $60,000 and the glass is still there. The silicone has to be on the back of the glass, trapping the glass between the wood and the silicone bead. The silicone will stick to finished wood like glue but will peel right off the glass with a sharp blade. I always install glass in picture frames with silicone but there needs to be a bead of silicone behind the glass. Your 3/16" deep rabbet is barely deep enough, it should be 1/4", but if you put silicone around the edges then smooth it and work it into the crevices with your finger it will work.
A good alternative is to make a strip with the right size rabbet in it and screw it on the back of the door.
Chuck Kettler
I have had very good luck using silicone. I built an entertainment center with 46" tall glass set in the framed door with Si and is still working fine after three moves and 16 years.
Steve Strickland
Steve Strickland
We glued glass optics to the holder for polishing. I've seen 6" thick stainless steel holders crack from the stress but the silicon never broke loose from the glass. I think we used RTV.
Glass aquariums are glued together with this stuff. I have no idea how well it sticks to wood, but it won't turn loose of glass. We cut it with a razor wire and cleaned it off with acetone.
Galen Vetterick
Like some of the others I used silicone to hold in a 24" x 32" piece of double strength glass in a gun display door and it has held for 30+ years!
Terry It will work. Of course the bead of silicone will show through the glass. I say it will work because I've been gluing mirror glass into wood mirrors for almost 25 years now. I have replace the brocken glass in some very old ones and litterally had to break out more glass and peel the stuff off. I use clear silicone caulking. It is a very good glue and does not harden even after many years.
Should hold...
John in NM
The time I had to remove silicone from wood it was awful, just plain awful.... stuff sticks alright.
But if you want to play it safe, get some of the clips, there are a pretty wide variety, and you might find the cabinet door has already got little biscuit slots for one kind (assuming you didn't make them yourself that is).
Re: Holding glass in with just silicone *LINK*
FredD
https://lh5.googleusercontent.com/-otv0zrijaK0/SyfjfQWdOnE/AAAAAAAADQU/Gs6MnetYZTE/s64-c/GlassStop.jpg
http://https://lh5.googleusercontent.com/-otv0zrijaK0/SyfjfQWdOnE/AAAAAAAADQU/Gs6MnetYZTE/s64-c/GlassStop.jpg
FredD
Terry as you can see Silicone or a product I believe is superior "PolySeamSeal will work just fine .
I like PolySeamSeal because it comes in colors and Clear and cleans up with water, therefore not near as messy and is odorless to boot.
A fact about Silicone, "Likit window company" the largest metal sash company in the Bay area when I built subdivisions bedded their glass in Silicone and if you broke a glass , most Glaziers would not fix it because it was Hell to remove.
For that reason Likit had one full time employee who did nothing but repair broken windows.
You will never have to fret about glass coming loose with either of the two products.
FredD
I agree with everything Moses said
Bill Tindall
Silicone will hold a mirror to a wall so it will damn sure hold a piece of glass in. The only issue can be that it holds it so well if there is expansion it will break the glass, been there and done that with exterior application as you describe (where there was more expansion/contraction with season.
Yes you can hold in with just silicone
Lee Schierer McKean, PA
They make aquariums with just glass and silicone sealant. I've also made terrariums out of just glass with silicone sealant making the joints. They last for years and years. I see no reason why you can't hold glass into a door with it. Make sure the glass is clean before you make the joints.
Lee
Contrarian view of PolySeamSeal....
Tim Greif - West of Chicago
Not sure why you love that suff so much Fred. I tried it based on your recommendations a while back whan recaulking the corners of my shower and it started coming off within a month. Yes, I removed the old stuff very well, then used caulk softener and scraped to get rid of all residue and then wiped down with acetone. Let it dry for a week. I agree it went on more easily than silicone, but the results were junk. I also found it to be less than popular on some tile forums, particularly John Bridge. LOML was pissed. I removed it and went back to GE Silicone. It's now been a couple years and no problems whatsoever.
