THE WOODRAT IS BACK!
Hoists
Hoists
Hoists
Carol Reed, Strawberry, AZ
I had a HF electric hoist in the rafters to lift sheets of plywood and any other thing that was beyond the limits of my back. It has failed.
My brother came over and dissected it and found that the centrifugal brake was not disengaging. The motor works with the brake pad removed but that won't do! Everything is properly lubed and such. No broken parts in the brake mechanism or anywhere else we can see. Both of us know our way around a VOM and electrical circuitry. Problem clearly seems to be electrical.
With no more information we had other than the Chinlish owner's manual exploded drawing, it would appear that centrifugal force induced an electromagnet to pull the brake pad away from the drum.
Any solutions to repair it or am I in the market for another?
Re: Hoists
Re: Hoists
Larry in NW OHIO
Carol There should be a magnet that pulls the brake away from the brake disk and letting the thing to work. Could the magnet be bad. Try to find the wires that work the magnet and hot wire it and see if it will work then. It goes without saying, be careful. Larry
Re: Hoists
Re: Hoists
Alan in Little Washington (NC)
I have one of those HF hoists in my shop. As Larry said the brake is released by a heavy duty solenoid (an electromagnet), it is not centrifugal. With no power applied, springs force the brake against a brake disk and prevent the motor and cable drum from rotating. When the hoist is powered, up or down, the solenoid is activated, removes the brake pressure, and allows the motor and cable drum to turn.
I don't know if there is a relay in the motor housing that operates the solenoid, but, with minor disassembly you should be able to test the break release solenoid separately.
Re: Hoists
Re: Hoists
Alan, yours looks to be the next size up from mine. Works great, doesn't it?
Larry, I will study the diagram again and see if I can locate the solenoid. The end of the motor gave us the clue with regard to a magnet. It maybe in this case, teh solenoid is buried in the motor. There was no apparent appendage that could be a solenoid, as I recall. And the brake clearly was not operating under power. We had live wires here and there, but we were careful.
My brother will be here again tomorrow. We'll look further. But even if we find the solenoid, what are the chances of finding a replacement? Sheesh!
Methinks I may be looking at a new hoist. I will get the size Alan has, if that is the case. Then I will need the 20% off any one item coupon.
Re: Hoists
Re: Hoists
My hoist is rated for 1300#. Remember the ratings are double line, like in my photo. Single line rating is half of that. I should added that the brake assembly is within the end of the motor housing (black plastic cover on mine). It will make a definite "clunk" when it engages and disengages.
The brake works pretty well except when lowering a 1400# planer and you try to stop it- it kept going until I briefly hit "up".
I only paid $40 for it on Ebay because it was missing the pendant switch. Since I was going to hard-wire it to a wall switch, that didn't matter to me.
Re: Hoists
Re: Hoists
Larry in NW OHIO
Carol Can you send me the name, model and serial #`s, or if you have the parts list, send that if you can and parts break down. There are places to get things. I wish that thing wasn`t so big and heavy, you could send it to me. Where is the brake located? Is it at the end of the motor, I would guess it would be at the end. If you could send any kind of break or parts break down I may be able to help. Hate to have you spend money on a whole outfit when all you may need is a coil. Best of luck. Larry
Re: Hoists
Re: Hoists
PM with link sent, Larry. Check your email.
Re: Hoists
Re: Hoists
Larry in NW OHIO
Carol Sumeplace around that brake disk there has to be some kind of electromagnet to push or pull that disk away from the stationary part of the brake. Could you send a picture of that area? If not just try and keep looking. I`m going to be leaving pretty soon, but I`ll be back this afternoon. If I get a chance I`ll try and call this place and see if I can get anything out of them that would help. Larry
Re: Hoists
Moses Yoder
Re: Chain Hoist *LINK*
Moses Yoder
If you get a new one, why not get a good 2 ton chain hoist, hand operated? No motor or gadgets to go bad. I had one for a while and never used it so I sold it. My dad has one on a carriage rolling on an I-beam in his garage that we use all the time for pulling engines and such. A hand operated chain hoist will last several generations.
Chain Hoist
Re: Hoists
Re: Chain Hoist
Simple answer, Moses. I cannot pull on things any more than I can lift them. Very bad back and neck and if I abuse it, I risk becoming a quadriplegic. I am allowed to press buttons, though. :)
I likely will not be able to continue woodworking for much longer, but for as long as I can with whatever aids I can employ, I will.
Re: Hoists
Moses Yoder
Re: Chain Hoist
Moses Yoder
Osteoperosis perhaps? Sorry about your situation, this is the first I heard of it. Take care of yourself.
