Did you ever misplace a tool under something??
Did you ever miss a tool in your shop?
Did you ever find it a while (days, weeks, months, etc.) later?
Did you ever say to yourself - I've REALLY got to clean up my shop?
I was wondering where my Starrett square happened to be. It's not like I don't have other combination squares. I was missing my Starrett. Lo and behold - there it was, under a pile of drawings for a project that I had set aside for a while. I'm REALLY glad I found it. Now I don't have to explain to the LOML where her Xmas present to me happens to be.
Re: Did you ever misplace a tool under something??
Howard Norman
Happens to me all of the time.
howard
Carol Reed, Strawberry, AZ
I'm getting ready to move, JL. I expect to find things I thought I sold during the last move seven years ago!
John McGaw
I have managed to lose tools under every possible condition. That is the reason I now have anything up to five of one type of tool (tape measures). Every now and then I'll get really ticked off at myself and start going through every inch of the house and shop and put all of the tools I locate into a box and then try to repatriate them. It never lasts. Probably the solution would be to put a high-powered RF locator beacon in/on every tool and have the computer scan the vicinity of the house for every tool every night and print me a list of where each stray item is.
Buy a second, you'll find it.
Jerry Gibbs
Of course not!
John in NM
I did once frantically search for a hose bib I was going to install, that I'd just had in my hands 30 minutes before. Took an hour to find it and a lot of frustration. Darn thing was sitting on top of my bench vise, in plain sight - just didn't expect to see it there so it never registered :D Frustration goes away fast when you realize how stupid the whole thing is!
And when you misplace the second...
John McGaw
...buy a third. Or, as in my case, you forget how many you actually have (or had) in the first place.
I thought it was normal to own five tape measures
Nathan
Re: Of course not!
Larry in NW OHIO
I`m glad to know that I`m not the only one that has trouble with runaway tools. Larry
Who Hasn't?
Dave's Not Here
Does it matter which layer you find it under?
Bill Howatt
Re: Did you ever Find It Under Something You Just
George Colonel's Workshop-Havertown PA
Good Morning JL,
That is my problem. Since I knew where it was hiding, I only moved the "something" when I needed the tool. Now that the something is moved, I see the tool isn't there. Now what to do? Currently missing a 4 inch square and a 100mm inch spanner wrench. I have a second square, but the 100mm spanner (Craftsman)is crucial to bandsaw happiness.
George
Not under, but inside of...
Joe Pack
I have a great little 24" level tucked safely away inside the overhead wall leading down into my basement. I even hung it on a nail so it wouldn't get knocked over and down the stairs. I assume as long as it hangs there, the stairwell and walls will never go out of plumb!
Sure wish I had my level back. :(
Yeah
Fortunately, however, when I couldn't find the jack, I didn't back the car out before I finding it. ;)
Jesse Cloud
I cannot keep a horizontal surface clean and unlittered. It just gets worse and worse until I can't find a six inch rule, probably my most used tool. Then I clean up shop and find half a dozen of them.
One trick that has helped me with that wrench that the bandsaw needs, etc. is to attach the wrench to the bandsaw with a couple of magnets. If you make it really easy to put things in their place, maybe it will happen....
Re: Many times. I even
Dale Stansbery
found a nearly new 8 ounce ball pein hammer in the interior of 1985 Ford conversion van driver side door. I had bought the van used in about 1995 and had to open the door panel to repair some wiring. It looked obvious that the hammer had been there since the conversion was done when the van was new.
No-never-not me. Really. ;-))
Don Orr
