200+ woodworking book reviews
A Priceless Treasure
Carol Reed, Strawberry, AZ
Some weeks ago I inquired about sharpening small drill bits. Among the varied responses came an offer from Larry in NW Ohio. He invited me to send my bits and he would sharpen them for me. After a flurry of emails I mailed him a box of 56 bits, all less than 1/4". Yesterday they came back, all with sharp ends ready for me to dull once again. Thank you, Larry.
Isn't it wonderful such priceless treasures as Larry walk among us!!!
Re: A Priceless Treasure
Ron Jones
Big attaboy for Larry! What a nice thing to do for a nice lady.
Would Larry share with us what he uses to sharpen them. I can sharpen fairly small ones on my Drill Doctor but ti doesn't do a very good job on bits below 3/16. I thought it was sharpening them OK until I bought new ones. The new ones definitely cut better. I can't sharpen the small ones by hand very well either.
Larry in NW OHIO
I used my Drill Doctor and the smallest bit was maybe 1/8 and how sharp we will leave that up to Carol. But the ones I tried was sharp to cut metal. Larry
Doug Ridley
What model DRill DR. do you recommend? There are so many.
Doug
Well they have obviously changed them. I have the 250 which used to be a step up from the bottom. I purchased the bottom of the line and it sucked. It used sanding drums to sharpen and tended to round over the blade and the paper got dull pretty fast. The 250 has a diamond drum and does a pretty good job. As I said above I was quite happy with it until I purchased some new small drills. That's when I discovered the new ones cut faster and cleaner than my sharpened ones.
I'm going to move up to the one that lets me sharpen larger bits. Those drills are expensive and I can buy them at flea mkts really cheap and recondition them. I'll be interested to see if the more expensive machines to a better job on the smaller bits. I also want one that does the split point to see how that works.
Larry in NW OHIO
I really can`t tell you what model to recomend since mine is around 13 years old. But it`s the 750 they had at the time. It also depends on what you need to do with it. If you only need to do up to a 1/2" drill that is all the model you`ll need to get to sharpen up to it. But if you think you`ll do bigger things later on get the bigger. And get one with a diamond wheel if there is a choice. I went to the Drill Doctor web site and they have a pretty nice comparison chart that will help you pick one out. Good luck. Larry
