Diamond plane blade
Diamond plane blade
Diamond plane blade
Bill Tindall
We have coated a plane blade with a diamond coating to see how it wears during planing. I thought you all might be interested to see what the sharpened edge of a plane blade looked like before use. This blade was sharpened by Steve Elliot, someone with more experience sharpening that anyone I know so I expect it is as sharp as any blade you have likely seen.
Re: Diamond plane blade
Larry in NW OHIO
Keith Newton----Little Rock, Arkansas
Bill, I guess this is the face,,,,,,,,, so what is the sharpness angle, and how do you sharpen a diamond coated blade?
Bill Tindall
The bevel is typical of a plane iron. This in fact is a Hock A2 for a Stanley #5 plane. Diamond cuts diamond. That in fact is how diamond jewelry is fashioned, exactly how we sharpen.....diamond on cast iron plate.
But no one has done this before so the objective of the experiment is to see what happens in planing and sharpening.
Larry in NW OHIO
Since you are experimenting with Diamond, would thid maybe something we might is in the market place sometime? Larry
Larry in NW OHIO
Bill You have tried Dia. and TiN. has anyone thought of a ceramic coating? I`m curious how that would hold up compared to them? Would it be considered a soft material to Dia. and TiN? I`ve read where they were trying ceramic in car engines for the cylinders, but that has been awhile back. But they have been using it for brakes. But it must not make money for them since my new truck has some kind of metal so it has to be replaced quicker. Larry
My bet is that,
It will hold up better at wider sharpness angles, where there is more support to the coating on the back side. It would only stand to reason that the sharper angle would leave a more fragile / brittle edge out there to fracture off.
My 2 �, and maybe even worth less.
Clint Searl
Clint Searl
TiN and TiC are considered ceramics. I have a 10" combo TS blade with ceramic teeth. In a mill setting, the ceramic teeth have shown to last many times longer than regular carbide teeth. I haven't cut enough to see a difference, but it gums up like any other blade.
Clint
