Electric motor -switch connect help
Larry in NW OHIO
I`m trying to hook a motor, two speed, up to a switch. I can not do it any more for some reason. Never could very well anyhow. I`m going to try and put a drawing of the switch and motor. I just need to know what to do with it. The switch on the bottom left needs a little explaination. When it is in the high position the two connections on the bottom left has contonnuity(sic) and you can figure the rest of it, if not just ask. Thank You Larry
Re: Electric motor -switch connect help
Brian Aust
Larry, you would connect your 120v hot ( I'm assuming the voltage ) to the common terminal on the switch. You should be using a three position switch, up would connect common to HI, down would connect common to LO, center would connect common to nothing - or an unused terminal. Your motor HI lead (blue) would be on switch HI terminal, same for LO(yellow). The (assuming) white wire from the motor would go to other side of your power supply.
Larry in NW OHIO
OK Brian I think I see it now. I could connect the white to the Hi and low side and the other two just connect to the hi to hi and low to low. What confused me was the one that says hi and lo. Thanks. Larry
del schisler
you want to leve the hi and low not conected to each other. The hi would go to the pos voltage and the other end to neg i guess black is hot or pos. than the neg is white this will get the fan going hi or fast . Now remove the hi and put the low there where you took off the hi and you will get low speed . this what i do to my fan in the shop.
Re:follow up
del schisler
I see now that you have color's wires You can use a pull switch with 3 wires on it now find the center or netural now this where the pos wire or black goes now swith the switch and find the next wire now put the blue or hi speed on their and of course the next is slow the yellow this will get your 2 speed's. I been doing electronic's for 6o yrs so this will work. The switch should come with a diagram good luck del
