Image of worn titanium nitride coated plane iron
Bill Tindall
First the "decoder ring" for the image label. A2 is the metal, this plane iron was coated with Titanium Nitride, this region of the plane iron experienced 50 meters of wear planing hard maple, the objective lens is 50X and illumination is bright field "BF" which means the image is of the light reflected perpendicular to the metal surface. This image is from the flat side of the plane iron. I can not image the beveled side with BF illumination because the stage will not hold the plane iron so the bevel reflects light back to the objective lens.
Two features stand out. First, and most obvious is that the TiN has worn off the first 36 microns of the edge. This loss was obvious with a hand lens at about30-40 meters of planing.
The second feature is more subtle, but note the texture of the worn surface. From this image I can not tell if the features are bumps or holes. If they are bumps it could mean we are seeing the projection of abrasion resistant carbide grains in this alloy. If they are pits, it could be an indication of metal loss by corrosion. Corrosion is a known dulling mechanism in higher speed wood milling.
One additional point. This blade was softened from a hardness of Rc60 to Rc54 by the coating process. I expected the hard maple to severely deform the edge and if anything this edge looks better than the A2 control at Rc 60.
Need help. I have 4 images from this experiment that could be best compared in side by side images, for example coated vs uncoated after wear. I have no means of assembling these images in side by side pairs for posting. If anyone can do this assembly I could like to send the originals for such processing and then we could post the results.
Also, what next? Any suggestions on what to do next with this TiN blade?
