Caning a Chair
Caning a Chair
Caning a Chair
George Colonel's Workshop-Havertown PA
Good Morning Friends,
I've been asked to supply some knowledge on the subject of caning. I am by no means expert in that field. Too bad Don Henthorn is no longer with us. He was a Master.
The following instructions apply to "sheet" cane, which is pre-woven in several different hole sizes.
First, it is necessary to remove all of the cane and spline from the chair seat (AND/OR back). This may require the removal of the chair seat for good access to the spline, and better working convenience.
Using a new razor blade in a utility knife, score around the outside of the spline to sever the finish coat. I use a mortising chisel to penetrate the spline down to the bottom of the groove. Tap the morticing chisel beneath the spline to lift it up from the groove. Use a paring/bench chisel to clean the groove sides. When completed, the groove should be smooth on both sides, and the bottom should be cleared of any glue and cane material.
Cane is produced with various size holes woven into it. Spline size varies as to the width of the groove. I always save a portion of the old spline, and a portion of the old cane to insure I order the correct sized replacements.
Once the correct sheet cane and spline are at hand, soak the cane for a couple hours/overnight in a bucket of water. Test the spline around the groove curves to insure it doesn't split. Should the spline crack/split, the cane needs to be wet where the bends will occur.
I generally lay in the spline around the groove while the cane is soaking. It allows me to carefully miter at corners and where the ends meet. The spline will "remember" bends and make installation over the cane an easier and quicker task.
Find the midpoint of the chair bottom and mark it at back and front. Use those references to insure alignment as the job progresses. Trim the sheet cane slightly oversize to the area of coverage. It may be necessary to strip strands of cane from the oversized area to permit the cane to be easily tapped into the groove at the corners and radii. Now, tap the cane into the chair seat around the entire circumference. Use a small length of spline to temporarily hold the cane in place as you work. Work outward in both directions from the initial spot until the sheet cane lies within the spline groove all around the chair.
Use cane wedges to gently tap the cane into the groove. I use my own wedges, and the width should approximate the width of the spline groove. I find it helpful to have several wide wedges which have rounded blades. I roll the spline in place down over the sheet cane. I make mine from hardwood, and also soak them before setting in the cane. I don't want them to damage the cane or the spline as work progresses. So a softer contact edge is desirable. Several wedges of various sizes/thicknesses and widths will make the job go more quickly.
The next step is running a bead of carpenters' glue around the groove atop the tapped in cane. The bead should occupy the full groove width. It will be further spread as the work progresses. Keep a dampened sponge handy.
Once the glue bead is layed in, the spline should be re-introduced to the groove. Begin with an initial point, such as ther middle of the seat back. Tap the spine into the groove with mallet and wedges. Don't use any more force than necessary. Work outward from both sides of the initial lay in point. Check alignment. Use a small piece of spline to temporarily anchor the cane as necessary. Tap the spline to uniform depth all around the chair seat. Sponge off residual water and glue. Set aside for several minutes while the glue tacks. Then using a fresh sharp blade in the utility knife, cut the excess cane from the outside perimeter/circumference of the seat. The knife must be angled so that no cane is visable on the outside of the spline. Try not to let the knife slip and score the outside rail of the chair seat. Clean up with a sponge.
The newly installed cane will sag somewhat until it dries overnight. Then it will be as tight as a drum. Examine the seat carefully sighting at a low angle to determine where small cane "hairs" are present. Trim them off with toenail clippers. I generally use spray shellac over cane. You can also use lacquer/toner to match other furniture.
George
Re: Caning a Chair
Re: Caning a Chair
FredD
That is a good instruction Colonel,you make it sound easy.
FredD
Re: Caning a Chair
Re: Caning a Chair
roger lance
George....thanks very much....I've got 4 chair seats to do and I'll be following your instructions closely....I think I've read you were in the Air Force and a pilot....I've got a little tale to tell regarding your former profession....I was an infantryman in the Army during the Cambodian invasion....while on a patrol, we accidently walked upon an undetermined number of NVA who opened up on us with a 51 caliber machine gun....it was like in the movie Predator where they fire as a group into the jungle with trees flying apart all around and those large bullets passing over us by inches or less....we were completely pinned down....completely out numbered....luckily we were able to contact an Air Force fighter that was in the general area....and he quickly found us via radio and our colored smoke....he dove directly at us and we were on our backs looking up at him....I swear I could actually see the whites of the pilot's eyes....as he pulled out of his dive, he opened up with all the machine guns on the plane.....straffing just past us toward where we were receiving fire....the pilot repeated this twice more and we were able to low crawl out of there safely....so thanks for that as well !!
Re: Caning a Chair
To Hear Fighter Pilots Talk, Roger
Is more Air than Force! Glad the advice helped.
George
Re: Caning a Chair
Fighter Pilots are OK by me.
roger lance
Re: Caning a Chair
A few more thoughts
Ralph Lipeles
If the old cane is stubbornly in place I use a 1/4" chisel ground down to 3/16". With the chisel I break up the cane into short lengths to make it easier to remove the spline. Check the base of the spline groove for cracks. If cracks are found, repair with glue and screws. Spline grooves vary in width. The most common are 3/16" and 7/32". Measure the cleaned groove and select a spline that just fits or is a hair tight.
Re: Caning a Chair
Re: Caning a Chair
Dave Paine
Thank you for the details. I had wondered about how to avoid the cane splitting in the groove, wetting makes sense. Doh!
I have printed out the message and will be using this for my first re-caning.
