We value your privacy.
The bed decking of a trailer was made from treated 2x6. The boards have curved into long 'C' shaped pieces so there are plenty of gaposis going on. The trailer is getting overhauled and I want to reuse as many of the pieces as possible.
Is there an easy way to straighten edges on long stock? I found this Shop Shot.
I was thinking of snapping a chalk line and using my circle saw then running it through the table saw.
Any easier suggestions?
With the recent power planer threads maybe its time to buy one.
Tom....I made a jig similar to the one you showed when I built my workbench and used a piece of 3/4" ply that was 8' long for the jig base....this jig works very well and you can work through a large stack of boards with it in short order on your table saw and get that one side straight....this jig was feature in Fine Woodworking years ago and I even made a maple runner with a t-shape to ride in the table saw's mitre slot and not come out accidently while making a cut....to get a 10' length, you could use a nice flat board instead of ply....otherwise, a jointer with roller tables to support the long stock will also give you a straight edge for sure.
Instead of a runner to fit the mitre slot, I use the same plywood sled but it's wider than any stock I want to straighten and I just use it against the fence. A couple of hold down clamps are fastened via T-nuts in the bottom side of the plywood.
Be very careful with the PT lumber dust. Also, it may not be treated to full thickness, this means if you trim the edges, you'll have them down to untreated wood.
I'm not concerned about rotting the wood. I bought the trailer 5 years ago and the wood wasn't in great shape. If it deteriorates more, no big deal. In some applications I think that we worry a bit too much about wood decay. Given a cradle to grave look at trailer decks I wonder if just using more wood isn't better resource use. I'm in central Texas...not a place where water/rot is that big a concern even in normal years. I would bet that plain ol' lumber would last about as long as treated, low grade, lumber in the long run.
Thanks for the input. I think using a bed that runs along the rip fence would be easier than a sled that runs in the crosscut trough.
If your confident with using a Tablesaw , try the way I have put a straight line rip on one side of a curved board for years.
In your particular case get a straight board, something like a 1x4 or 6 about ten feet long and place it against the concave edge of the curved board .measure the narrowest combination of both boards and set the rip fence a little less.
Holding the boards with both hands, run them though and you will have a straight edge on the convex or off fall side of the board.
With a little practice you can run though a stack of Pretzels in no time at all.
If the straight board you use to rip with is a little less then ten feet , no problem, hold it shy of both ends and rip away.
I am a little sceptical of the type that runs in the miter slot. It seems to me that it would get away from me on long stock and it would jump out of the slot. Mind you, I don't have one and have never tried it, but it just seems like it would be a struggle for me.
I would use a nice straight piece of wood and screw it to the crooked piece with a few screws. With a drill of impact driver it would take seconds to install and remove the strait edge.
For wood that has been used as a trailer floor I would use and old saw blade. Unless you trailer is in a lot cleaner condition than the ones around here, I would be counting on hitting some grit.
When I grew up on the farm, we built a number of trailer floors. We used tree run lumber from a sawmill. To straighten the board we sawed into them from the convex (bulging) side about half way through and "broke their backs" so we could bend them easier. Sometimes we cut out a very thin V notch. Straightening them closed the notches. The notches were over the frame supports to support them. Hey, its a trailer and this way you don't lose all the width and have to buy additional lumber that's new and won't match.
Tom....it does take a bit of an effort to make this jig well and if you aren't making it for long term use, its really over kill for what you want to do....so I'm voting with just attaching a straight edge to your pieces and cutting from there....this method will work with a circular saw as well.
