Revist Power hand planers
Larry in NW OHIO
One more question on the planers. Do the blades on these planers automaticly set themselves when they are changed? Thank you Larry
Re: Revist Power hand planers
The steel blades on my Makita come with a little gauge block - once you fasten the blade to the carrier using this guide block, the depth is automatically set.
The carbide blades (buying those was a good move on my part) are even more automatically set for depth.
I think that's true of most modern planers.
FredD
The Makita I have , circa 1975 will set the new blades to a factory settin.
The depth of cut is controlled by a knob on the front of the plane.
The Porter-cable power Block plane was entirely different.
The steel blades that came with it were sharpened right in the planer, you didn't take them or it actually out , it is a spiral one piece blade.
I bought a Carbide spiral cutter for it and that ended the sharpening.
FredD
Keith Newton----Little Rock, Arkansas
Yes, there is a fixture that indexes a little part that drops into a slot in the head, to the edge after it has been sharpened.
There is also a little honing fixture that holds both blades, so when you hone, both blades are being honed at the same time, and the angle for the bevel is automatic.
I have one of those big Japanese bread loaf size water stones, which makes it fast and easy.
But that follows grinding, which I do on my smallest TS, where I use a white / alundum wheel, with a cross fence like you would make cove, along with a Kool-mist spray to keep the grind cool.
