We value your privacy.
I just removed the old glass from the first of 14 casement windows that need new glass. The wood stop, I believe called glazing bead, was stapled in as well as being set in a caulk bed. It did not survive.
What would be the best wood from which to make new glazing bead?
In this case the glass is double pane which has an internal frame and sealant around the edge. To conceal that the wood glazing bead is required, and in fact, is about 3/4" wide. Rather than a square profile and glazing to fill the corner, the profile of the glazing bead has a beveled edge that mimics glazing and the whole bead is well seated in a bed of caulk.
Depends, if the wood that you removed was damaged/rotted due to moisture than I would use a wood that is durable like Redwood, Cedar, White oak, locust, walnut etc. that you normally would use for outdoor furniture. If you are like me (and most woodworkers), you probably have enough scrap of several species that you could use for the job. If the wood is going to be painted and the wood you removed was solid, it really wouldn't matter if you use pine.
Thanks for the responses. I hope all the windows are in as good a shape as the first one. There was no rot or even any sign of moisture. The sealant on the double pane glass had melted and the windows fogged on the inside.
Tomorrow I'll get some clear pine and start making glazing bead.
You want Ponderosa Pine or something similar, Not yellow pine or white pine. Straight grained old growth stuff would be the best. See if you have an old line mill work supplier locally for a supply of the wood. This would be less prone to warp than yellow pine and more decay resistant than either yellow or white.
There are companies that repair such windows locally. You might be able to find one in your area and them might be willing to give you some help on removing the stops and salvaging them.
Also look into treating the wood with some type of clear preservative like Bora Care.
Pat here is a site that I used a couple of times, but it`s been a few years. Maybe you could get an idea or find something to help. Good Luck Larry www.pickenswindowparts.com
That's not really old for a house , wood window companies then and now , were generally Anderson, Pella and Marvin in that order for Casement windows especially.
