Has anyone installed drop pulls on a curved drawer
Bill Tindall
Need help. The post hole angles are critical and there must be some way of reliably drilling at the angles required.
Re: Has anyone installed drop pulls on a curved drawer
Steve Strickland
Re: Has anyone installed drop pulls on a curved dr *LINK*
Steve Strickland
Here's how we do it in puzzle making - use an angled jig with spacer blocks shown in link below.
Drilling This Puzzle
clarification
Bill Tindall
Just when I thought I was done with the adversity of making something with a bow front I get to the final step of draw pull installation. I figure the post holes for drop pulls need to be at some angle for the back plates to lay flat. That conclusion would lead to the holes being drilled perpendicular to the tangent of the arc at each hole location.
Some test holes revealed another problem. The Holes in the posts need to be in a line or the bales will bind. Hence the post holes need to be perpendicular to the same plane which is not the planes tangent the the arc at either hole.....maybe an average between them?
There are plenty of bow, serpentine and oxbow front antique pieces so someone figured out a reliable way to drill the holes to get the plates to lay flat and the bales to drop freely. Anybody done it or read how it's done?
Re: clarification
Robin Corell in Atascadero CA
I repaired a drawer on a serpentine front dresser and there didn't seem to be any problem with the bails. The holes were drilled parallel and there was enough room on the threaded shank to allow the backing plates to be slightly cocked to hit the drawer face. It has been a while and I don�t recall if the holes in the backing plates had been modified or if they were straight from the factory.
One of the holes for the part that holds the bail on a drawer I didn�t repair had become enlarged and the handle was loose. Every once in a while the bail would slip out. The problem was that if the screw on the back was tightened the bail would bind because the backing plate would cause the exact problem you found when drilling the holes tangent to the curve. I was asked if I could also fix this and I was at a loss for a quick fix and declined to repair that drawer.
I will be interested in how you solve this problem so post some pics or an explanation of what worked.
Robin
No I haven't
Gary Smyth
Now don�t get on me because they aren�t drop pulls. There are two serpentine front pieces around here and they are manufactured pieces - not high end. The hardware is original and pot metal inexpensive. For what it�s worth, this is how these were made. The bails straddle the curve and the posts are somewhat splayed not necessarily parallel to the viewing front of the chest. The bails work fine with this arrangement and have for at least since the 1950's. The posts have some freedom in the drilled hole and are fastened on the inside by square nuts. The threaded posts protrude into the drawer by at least 1/8� beyond the nut. The circular rings and knobs are drilled straight through the drawer front piece and are parallel to a straight on viewing angle. They are anchored by a wide head slotted screw. This is the way these were built. Perhaps others can provide better solutions.
that's it
Bill Tindall
I found the pulls are also called "rosette pulls" and that is what is on your chest.
I have one solution.....
Bill Tindall
cut a profile in a block of wood to match the profile of the bow front drawer in the area where the pull will be installed. The opposite surface from this profile will remain flat. Locate and drill two holes on the flat surface, perpendicular to this surface and spaced appropriate for the pulls's posts.
Place this block on the drawer in the correct location for the pull. Using the guide block drill the two holes for the posts. Presuming the guide block is correctly located the resulting holes will be properly space and aligned for the bale to swing without binding.
Well that didn't work
Bill Tindall
But If after drilling the holes I resaw the flat side to be uniform thickness with the curved side I think it will
