Have a question? Ask Woody!
Help to get new WW machine running
Carol Reed, Strawberry, AZ
Need some help. The idea is to push the trigger switch that operates a DPDT relay that in turn operates an air solenoid. The relay is to stay �on� until the break switch is opened. The circuit is AC. The relay has to be wired to �latch.� I thought had it right, but I proved to be too obtuse!
Can anyone draw in the proper connections for me?
Re: Help to get new WW machine running
Chuck in Mtl.
that radio shack number tells me this relay is the non-latching type. if you obtain a latching type of relay then it will latch and have a reset feature that ordinary relays do not have. the solenoid is wired to the output terminals of the relay and the center poles are how and neutral respectively.
Galen Vetterick
AC Nuetral to relay terminal 7and to white on solenoid.
Tie into hot feed after fuse before the push button and run to relay terminals 5 and 6.
Relay terminal 3 to black on solenoid.
Terminal 4 is tied into line between the push buttons.
The relay contact 4-6 locks in the circuit around first momentary push button.
When you push to open the second normally closed PB contact it allows the relay to drop out.
Galen Vetterick
A latch relay is not needed as you can use one set of relay contacts to hold in the circuit till the second NC push button is opened.
Latch relay can be used too, I agree, but lock in contacts used very common.
Brian Aust
Carol, from your 120v source, wire to your stop button, from your stop button to your start button, wire your start button in parallel with a N.O. set of contacts in your relay, then through the coil of your relay, and back to 120v neutral. You'll run a separate 120v through the other N.O. contact to the solenoid. So you'll have 120v through the N.C. stop button to the start button, when you hit start you'll send 120v to the coil, which will pull in the relay, so it latches itself, and also sends power to the solenoid.
Robby Wright in San Marcos, CA
Carol - Try this diagram:
If you get sparks, I didn't have anything to do with it.... :D
Forgot Something.....
The wire from pin 5 of the relay to the solenoid to the fuse does not connect to anything else. Dots signify connections.
Thanks, Galen, but does not the 'break' switch also tie to 8 on the relay? See drawing.
OK, buts that different from what Galen suggested.
Somebody can check me, but I used to be an industrial electrician and electricial contractor. I would normally have drawn it as a ladder diagram, but I thought using your symbols would be easier for you.
Thanks, Robby, for using my drawing. It does make it easier.
Not withstanding your 'sparks' warning, I am going to print this out and go give it a try.
I just traced Galen's diagram and we both drew essentially the same thing.
Galen Vetterick
You knew what to do all along! :D
Bill Turpin WNC mountains
Carol: your final diagram will work. Robby's needs a jumper from 5 to 6 on the relay.
Galen Vetterick
Yes, mine just allows short jumper to power both relay contact commons.
Designed controls for 35 years for municipal and industrial water treatment plant equipment. Old timers like me started in relay logic way before PLC.
Bob Entwisle in NJ
So far none of the responses you have gotten are correct.
Some just won't work, a couple will work but will allow the load current to flow momentarily through the presumably lower rated start and stop switches, which may or may not cause problems down the road.
If you don't know how to do this, hire an electrician.
It might cost a hundred bucks but at least his insurance will cover your shop if it burns down due to his mistake.
Bob in NJ
Gee, Bob, you are tough!
My neighbor is an electrician. He confessed to knowing nothing about what I was doing. He wires houses.
Bob Entwisle in NJ
I'm sorry to be tough, but this isn't 1.5v batteries and flashlight bulbs in in first grade, this is (from your fuse) 10 amps at 120VAC, and can and will burn your shop down given the chance.
Bob in NJ
I wired it according to Robbie's diagram.
I can hear the relay operate. I can push the break switch and hear the relay drop out.
However, the solenoid is not working. Tomorrow I will isolate it and just apply switched power to see if works. Maybe I already fried it. :(
Brain is fried. Time to close the shop. But we're close!
But to hear a warning and a declaration that what has been presented in incorrect without corrections offered is not helpful. Galen's credentials appear to be much better than my electrician neighbor. And since you offered the warning, exactly what is wrong? BTW, thanks for your interest in keeping my shop from burning to the ground.
Bob Entwisle in NJ
Check your email
Bob Entwisle in NJ
What is wrong is:
When the start switch is actuated, the 5 to 6 jumper on the relay, allows the load current to flow momentarily through the start switch, until the relay contacts pick up the load.
Bob in NJ
Bob Entwisle in NJ
But then again, i looked too fast at the diagram,
I am wrong, (once again).
duh
My apologies to You Carol, and Galen.
Chuck in Mtl.
you don't even need to incorporate a relay...just a switch to turn the solenoid on or off.
Alan in Little Washington (NC)
Carol,
Too bad it took so long to find out both suggested wiring diagrams were the same- they just wired the latching circuit contacts opposite. Did you get your solenoid to work?
Are you sure your solenoid coil is 120VAC?
I have a number of air solenoids that run my DC autogates. The ones I'm using are low voltage (24VDC), but when I did my initial experiments I used a number of different types I got off Ebay- they had coil voltages of 120VAC, 220VAC, 24VAC or 24VDC, 12VDC, etc.- all are common ratings.
If you hear the solenoid "click" but are not getting air flow and the solenoid has more than two ports (I have 5/2 SMC solenoids - five ports, two position), it could be that you have not connected your air lines correctly and/or have plugs in the wrong ports.
