sharpening small drill bits
Carol Reed, Strawberry, AZ
My jar of dull drill bits runneth over. I mean those less than 1/4" in diameter.
I do have an old Drill Doctor, currently in the Witness Protection Program, as it is no where to be found! However, that said, those small bits groove the sharpening stone terribly. And thus do a lousy job.
I also have one of those jigs that holds a bit to the side of a grinder wheel. I have great difficulty seeing that the bit is properly aligned. Also, the grinding wheels are sufficiently shrouded that this is an awkward solution.
So! Suggestions? Not adverse to buying more bits, but that was my solution for years. Now I have enough bits to practice sharpening them with no regrets if I screw a few of them up.
Thinking of building something. Google returned several clever solutions if only I was a machinist!
If I made a round plate with silicon carbide sandpaper glued to it, mounted on a motor (what RPM?), and used the drill bit jig under very good light and magnification...
Your thoughts and ideas are appreciated.
