We value your privacy.
I have an old fluorescent fixture in my shop. Used to be that a pair of bulbs lasted years. Recently they went bad, so I replaced them. One and then the other. Within the last week. Now they are dim and flickering and the end of one is darkened. Did I buy the wrong bulbs? Or is the ballast going bad? Or did I get bad bulbs? I bought F40T12 GE cool white bulbs.
my philosophy is to use what ever and replace ballast with quality balast as needed. The electronic ballasts don't vibrate the fixtures so there is less incentive to buy a high quality fixture to eliminate the hum.
The usual small PITA, but I remembered I had a lightly used fixture in the shed, so I took down the older one and replaced it with the newer one. Moved it slightly so that the bulbs are centered over the TS blade. Wouldn't you know, when I walked in carrying the replacement, the old one lit up like it was new. Didn't help. Too late to go to work now. It was amazing the difference in the weight of the two fixtures. I bet the new one weighed half as much.
Ron, I bought inexpensive Lowe's commercial grade t-8 fixtures. Out of 10 purchased I've replaced 12. Two ballasts went out within the return period so I got new fixtures. The rest I replaced with good grade ballasts as they went out. I've since been adding good fixtures from the electrical supply house that cost almost twice the price of Lowe's but still cheaper than buying and then replacing the ballast in 5 or 6 months.
The replacement ballasts are Philips. I don't know how much they cost because when I bought my last batch in April they were $14 each. When I looked at the supply companies site they show $26. Many companies around here give commercial discounts to everyone so that might be the difference.
I built my 30 X 30 workshop about 6~7 years ago. I installed 20 some 4' T8 fixtures - most of which I paid less than $15 for with bulbs. Mine are hung by chains about 2~4" below the ceiling and are plugged into ceiling mounted switched outlets (I have 4 light switches for the fluorescent and 6 other Halogen bulb ceiling lights). I used the cheaper ones since they are quite easy to change if necessary. That said I have detected no "hum" from any fixtures, and had 1 fail when first installed (replaced by the store). Since then I have had no failures except have replaced a few bulbs. I did change many of the bulbs to the "sunlight" type bulbs as they have a bluer spectrum light which I find (with my 70 year old eyes) makes it easier to see fine pencil marks, flaws etc. I really don't recommend buying more expensive fixtures - replacing the ballasts usually costs much more than a new reasonable priced fixture - not considering the labor involved.
I did the same thing in my 30x40 shop. Of the 20 el cheapo fixtures I hung, I've replaced about a third of the ballasts. The net cost is still less than replacing the bad and ugly with the good.
