non-parallel clamping
Murray
What's a good way to glue up a panel of solid wood when the outside edges to be clamped are not parallel? I'm repairing a cradle that has trapezoidal ends.
Murray
One obvious way
David Yoho
Probably the easiest would be to create a square panel first, giving you a way to apply your clamps in a standard fashion. Then cut the shape you need after the glue is dry.
This is the approach I would take if doing that. Sure you waste a little wood but it resolves the clamping problem, which may have lead to the failure of the other one.
Re: One obvious way
Bruce, a MN Galoot
I'm with you here. Trying to clamp at angles gets to be frustrating at best.
Otherwise, it's possible to temporarily glue on some blocks that get knocked off later and clamp across those.
Re: non-parallel clamping
AZ in Colorado Springs
Cut a couple of triangular pieces (the off cuts made when you built the cradle would work well) that complement the sides to form a rectangle. Lay those next to the trapezoid, and you'll have a larger overall shape that's rectangular (or maybe square) and you can use clamps to pull the joint tight. You might have to add some cauls across the whole works to keep everything flat when you tighten the clamps.
Agree
Bill Tindall
I have some repairs exactly as described.
Re: One obvious way
Robin Corell in Atascadero CA
The obvious way to me is to use hot hide glue, that way you would not need to use any clamps due to the high tack strength. the other property that makes hot hide glue the obvious solution is that you can do a rub joint and as it dries it draws the two pieces tighter and the glue line becomes even less noticable.
I guess this just goes to show that nothing is obvoius in wood working.
Robin
Re: non-parallel clamping - did we miss the point?
North of the Border
Is Murray trying to glue up a new board to an existing one? If so, the suggestion to start with a rectangular or square glue-up doesn't work here. Here's how I would do it:
1) Make some "U" shaped blocks from 1/2" or 3/4" plywood scraps (like this)
(add adhesive-backed sandpapers to the inside top and bottom faces)
2) The opening of the block's mouth would be the thickness of the boards to be glued
3) Insert the blocks along the edge of the board with the odd shape and clamp the blocks down with C-clamps or F-clamps
4) Place the clamp heads at the blocks accordingly and the other ends on the edge of the other board.
Re: One obvious way
David Yoho
The hide glue is certainly a good way to go. However, as my title states, my suggestion was one not the obvious way
Guilty
David Yoho
I went back and read the post again and, you're right, he is asking about repairing what he has, not build another one. Somewhere I got the idea he was making a second one, which is what I based my response on.
Given he wants to repair the one that came apart, I lean toward the hide glue idea Robin mentions above. One could also use different methods of adding angled blocks along the outside to help with clamp alignment, hot glue blocks of wood to the surface on either side of the joint, clamp, and remove when dry, or an idea such as you mention.
Re: Guilty
Murray
David,
I think I would like to try this hot glue-block method, but I'm not acquainted with it. Can you give me any more details?
Re: Guilty
David Yoho
The idea is to take some blocks of wood whatever size you think necessary and use some hot melt glue to stick them on either side of the joint line. They can be removed afterward and they give you something to apply your clamps to. For a panel such as you're working on I would probably do this on both faces so the clamping pressure keeps it flat.
bricofleur
I would use wedges to make the clamps parallel to the project.
Best,
Serge
http://atelierdubricoleur.wordpress.com
