We value your privacy.
The task is to locate the drawer dividers/blades on each side panel of a chest of drawers. The divider mortise and tenon or sliding dovetail is located front and back and on each side of the case and ideally each set of dividers, front and back are exactly the same spacing. No matter what technique I use to mark these locations I wind up with small but annoying errors that leave the spacing between dividers slightly different side to side, or front to back.
What do you all do to mark divider locations in a case piece? On this chest I will be using sliding half dovetails for the dividers.
When I need to make one or more things exactly the same size I use a reference piece and then build everything to fit the reference.
It sounds like it's too late for that in your case and it seems to me maybe you're trying to locate an exact center line? Try making 2 (or more if needed) reference pieces, both exactly the same, and use them for left-right positioning. Use a shave-to-fit method creeping up on the exact right size.
I put both pieces together, usually laying on the bench, and mark both at the same time. If the spaces are graduated in height, I make a story board and mark from that. If they are all the same, I set my combination square to the opening size, and a second combination square to the exact thickness of the dividers. I make the marks from the references. For me, measuring and marking from a ruler is an invitation to error, and it's better to be consistent.
Marking the sides as you describe as a pair ensures the spacing is the same on each. If the front is marked first, for example, how do you transfer the front marks to the back, for the back dividers?
To transfer (and check) front to rear dividers for drawers I use drafting tools, T squares, and drafting triangles to get me (very) close. If you have the front located and need to transfer that to the rear, if the cabinet is square, then hold the T-square or triangle on the edge of the divider at the front and run marks on either side of the divider. They are directly transferable. Once where you know where the marks are at the rear you can double check by the use of large outside dividers/matching cut wood test spacers to check. Tweaking plus or minus 1/32 is all you should have to do if the cabinet is close to square.
By the way. A drafting T-Square is identified by a plain stainless steel, flexible blade and no length markings. Harder now to locate (largely replaced by CAD and plotters) they still come in sizes from 12" to at least 60" but can get pricey at the long lengths. They do require care though as if they drop or stuff is placed on top of them, chances are the're out. Picture 1 shows drawer runners along divider edge using triangles for checking square. Picture 2 shows dead accurate drafting triangles and T-square. Picture 3 shows T-square placed along front divider on cabiner frame. It runs to the rear dust panel batten where it was marked for rear of divider.
I have a nice plastic triangle and my tee square and board from high school drafting class. They have done two houses and lots of furniture though. But I lust for what you have in the PIC's
To go from front to back, I use the largest, accurate square I have. For pieces that aren't too deep I use a combination square, but that has a rather small reference surface. I also use a big orange drafting square, like the one Gary shows, but I added a reference surface to one edge. A square strip of walnut (about 3/8") with a groove down the middle of the length. I cut the groove with a thin-kerf blade on the table saw, and was careful that the walnut was straight and the groove a consistent depth. I glued the wood to the plastic with Gorilla glue. Once in a while I use a framing square, but it is awkward to use and the accuracy of it makes me nervous.
Often when we have a problem with one step in working, the solution is in the previous step. I make sure that the material for the project is as perfect as I can make it; edges straight and parallel, ends square, sizes consistent. That way the material itself can serve as a reference.
If it's a complex case, I will lay the two sides flat on the bench with the inside faces up, and either the front or back edges butted together. That way I can easily see, and check with a square that everything lines up.
We rarely talk about the importance of good stock preparation and careful layout work, but those are the steps that make everything else easier. I try to do all my measuring, marking and head scratching as early as possible. I used to think that all those little errors would somehow cancel each other out, but experience tells me the all gather at the most visible place they can find.
