OT - My chainsaw cuts curves, why?
Ray Carson - Lawrenceville, NJ
Hello fellow woodworkers,
I feel like I haven't been here in ages. My woodworking has been reduced to fixing things for everyone under the sun. No time to do my own. Oooyy!! Anyway.....
I wasn't sure if I should post this here or on the round side. I know a lot of guys over there use them to cut down logs for turning.
So....my neighbor wants help cutting down a small tree. No problem. When I go to cut up the tree into manageble pieces, the saw is having a tendency to cut curves. I do my best to cut straight and it goes where it wants to.
Any ideas to why? Dull blade, blade tension, grain in the wood? This has never happened before.
Perplexed,
Ray
Re: OT - My chainsaw cuts curves, why?
Chuck in Mtl.
the teeth are more dull on one side than the other...sharpen the well so it cuts evenly and don't forget to cut the rakers...sometimes its best to just buy a new chain and have the old one professionally done.
Larry in NW OHIO
As chuck said, dull blade and the best thing to do is have it professionally sharpened, unless you have a power sharpener and know how to use it. Good luck. Larry
Bill Turpin WNC mountains
Un-even sharpening. Best to start with new or professionally sharpened. To keep the chain even, find the worst tooth, count the number of file strokes necessary, then sharpen all the other teeth the same number of strokes. If possible find the double teeth, start there and go around til back to double teeth. Alternate the direction of file stroke, go around once. If you are doing more than two/three strokes for each side of chain...SHARPEN SOONER or stop cutting rocks.
not duller but longer
Bill Tindall
The teeth on one side are longer than the other side and the bar wanders to the long teeth side. I don't know how one could wind up with teeth duller on one side than the other. Carlson makes a handy gauge for measuring teeth length. Available from any logging supply.
Learn to file you chains. A file holder helps, again available from wherever Stihl or Husky is sold. Also helps if you find some means of holding the saw steady. I clamp my saws to the bench, unless I am filing in the woods. Your chains will last vastly longer if you file them your self, as needed. The commercial grinders tend to take too much off. A few file strokes is all that should be needed unless you are using the modern chisel tooth chains in dirty stuff in which case the points can get very dull very quick.
Myths of chain sharpening *LINK*
Tom Dunlap
As an arborist I've had a chainsaw in my hands more than any other tool. Over the years I've heard all of the myths of saw sharpening and been taught the right way to sharpen by some real pros.
Woodworkers will understand how this phenomenon of curved cutting happens better than anyone.
It is NOT the sharpness of the tooth NOR the length of the tooth that determines how much wood is shaved off by the chain. The sole determination of that is set by the 'depth guage' or 'raker'. This is the rounded bit in front of the cutting edge of the tooth. Think of the chain like a plane. If the edge of the plane is set out from the sole it will dig a big bite, set it low and it'll shave a nice even smooth ribbon with little effort. Another visual is to think of using a chisel as a shave or chopping out with a hammer.
If a straight edge is laid across the tops of the sawchain you'll see that there is an air gap below each cutting edge. This gap above the depth gauge is the amount of wood that the tooth will shave off each time it runs through the kerf.
If the depth gauges aren't the same for each tooth then differing amounts of wood will be shaved off. If more gap is found on one side then that is the side that will 'pull chain' and cause it to curve. No amount of sharp chain will change this.
You could have a chain with a brand new set of teeth on one side and 3/4 gone teeth on the other. As long as the depth gauges are the same it WILL cut straight. I've found this on my saws over the years.
My favorite sharpening tool is one made by Pferd Chain Sharp. It has a round file and a flat file in one fixture. The depth gauges are taken off every time the tooth is sharpened. The Pferd tool is quite easy to use too. I've given it to 'new hires' with about five minutes of instructions and they can sharpen a saw quite well. It may take a few chains to understand how much pressure to apply. After that you'll be cutting square again.
http://www.pferdusa.com/products/201b/201b01/index.html
I traded my Foley saw sharpener many years ago and went manual. I love sharpening chain!
For more information and a better explanation of chain sharpening take a look at Tim Ard's page. He teaches classes about felling and saw use all over the country.
Forest Apps
Karma
The wood gods are paying you back for sins in a prior life.
[or your chain or bar needs some real care] :D
chip size is not solely dependent on raker height
Bill Tindall
If you leave the rakers alone and file more of the teeth off on one side than the other, a common event when learning to sharpen as most people are more adept at filing one side than the other, the teeth on one side will be longer, the chip on this side will be larger and the saw will cut to that side. The chip size is not independent of tooth length. Rather it is a combination of tooth length and raker length. Since it is vastly easier to get, and keep, the rakers all the same the most common cause of curved cuts is uneven tooth length.......in my experience.
To put it another way if someone was to hand you a saw that cut a curve, would you file the rakers to match the varying tooth length or the offending long teeth.
Re: chip size...species and gullet size
Tom Dunlap
Chip size is dependent on species and density of the wood.
Also, the gullet of the tooth, the space in front of the curved cutting face and the back of the depth gauge, fills with a shaving of wood then it's broken off. The next tooth...actually only about 1/3 or less of the teeth are actually cutting at a given moment because of the sine wave that the chain creates as it cuts...will then fill with a shaving until its ejected off the tip or the end of the bar rail. Think of a line of coal cars.
Oregon Chain used to have some videos of chain cutting. Fascinating to see the high speed photography and how they manipulated it so that it is easy to see what is going on when the chain is zipping around.
I heated my 1880's 2 story 4 bedroom totally with wood for about 8 years. At the time I had bad windows and no insulation so I actually used over 14 cord one year. I have now installed gas and central air but remember the saws well. I remember one time helping my friend cut wood with his saws. It cut so crooked you could cut a wheel out of a large log. Upon examination, I found he had sharpened the chain using a clamp on guide, setting a different angle when sharpening one side than the other. Hitting a rock or nail with one side of the chain will also cause some of the same symptoms. I am sure the rakers could have some effect, but I also keep them fairly low.
Dale Lenz
What cause my CS to cut curves
Dale Lenz
On a CS bar you have a groove that the chain rides in and outside the groove on either side I�ll call them rails that support the chain, while it�s moving along the bar. The rails at the bottom of the CS bar in front of the dogs sometimes get worn differently; one side is lower than the other, i.e. makes the chain tilt towards the lower side of the worn rail, hence the curve cut. To correct the problem, you can either file the CS bar flat to the adjacent rail, as they were originally made or the quick and dirty method is to flip the bar over, where the damage rails are on top of the bar and you have a fresh even chain rail on the bottom of the CS bar. At least this has been my experience, to a curve sawing cut with a CS.
What causes the problem, of uneven wear of the CS bar: No sure, operator error as in letting the chain get too loose, CS not oiling enough, or ??
When sharpening the chain lay a straight edge over the cutters while on the CS bar, if the rakes are touching the straight edge, they are too high and needs to be lowered. I like to grind the rakes down a little; Using an elect hand grinder and just barely touch the rake to remove maybe a 1/16". Note: The rakes are suppose to wear down as you are sawing, sometimes they don't. Just beware, when you put the freshly sharpen saw with lower rakes, the saw will really dig in and will pull the saw forward, while cutting aggressively, makes a Hugh difference! It�s not dangers as long as you know what is going to happen, kinda like running a router clock-wise, you know the router is going to try to climb cut, and will attempt to pull the router out of your hands.
Not likely to be bar wear
Tom Dunlap
Dressing a bar is important too.
In 35 years of work in tree care I haven't seen a bar with rails so worn that it caused the saw to cut crooked...it was always the depth gauges/rakers. I have heard of it though on arborist discussion forums.
1/16 is WAY too much clearance. Each size chain has a spec....generally about .030 or so.
Lowering the depth gauges IS dangerous...much more dangerous than running a router backwards. The saw can grab or kick from the aggressive appetite of the chain. Think of shaving not gouging with a chisel.
Chainsaws have been called the most constructive and destructive tools ever made. Thousands of people go to the ER every year with nasty cuts.
Dale Lenz
Re: Not likely to be bar wear
Dale Lenz
Tom,
You have run a saw more than me, that's for sure. But, the uneven worn rails on my saws did make the saw cut in a "(�. That has been my observation, and I've solved the problem as my above post stated. As others have posted there could be other problems, also.
I like an aggressive saw.
That's my story and I'm sticking to it.
VR
Thanks to all for the advice.
Ray Carson, Lawrenceville, NJ
Hello. Sry for the late response, life has been hectic lately.
Turns out a well needed cleaning, adjustment and a new chain put things back in working order.
Thanks again,
Ray
