Furniture hardware(Pic)
Larry in NW OHIO
Going to try and post a pic of the bedroom furniture handles I`m looking for, that should make it easier to find.
BINGO Surprized me that worked for me. Thanks to everyone helping. Larry
Larry in NW OHIO
Re: Furniture hardware(Pic)
FredD
Looks like a door pull on the right
FredD
Re: Furniture hardware(Pic) *LINK*
Try Van Dyke's Restorer's hardware, 800-787-3355. If they don't have a replica of the pattern, they may point you to someone else.
http://www.vandykes.com
Have you looked inside the drawers
Gary Smyth
the underside bottoms, and on the rear panel to find a clue as to who built the piece? Even a furniture store? If you can come up with a name, model number, dates, and they are still in business you might be able to contact them and find a source through them for the furniture/hardware manufacturer (if they are still in business). The pic doesn't seem to show the casting as brass. Are they brass or pot metal with a brass coating? I don't know your value on the furniture and I know that it will be expensive, but since you have others to match, from which a mold could be made, you could find a foundry who will make what you need. You could also find a furniture restoration place - the largest you can locate - and let them go through their inventory. They may have had a matching piece of furniture pass through their door.
Larry in NW OHIO
I`m sorry I didn`t specify which is which. The top right is a drawer pull and the bottom left is a door pull, it should be turned 1/4 turn clock wise. Larry
