Sears dovetail fixture and unknown bit
Gary Smyth
I have just spent 40 minutes talking with Sears 1-800 parts, and they have not been able to assist. The store was worse. I have a Sears dovetail fixture #25450. The manual (page 5) tells me that I need to install a �#25414 and #25415 bit for making through dovetails and a #25505 or #26318 bit for half blind joints�. There is no description for those bits that I can find, and Sears tells me that the half blind bit part numbers are springs or levers or something else not even related to the dovetail fixture. Now we all know that the bit does not have to be a Sears bit, but I want a description, and neither the manual, nor Sears parts, describes the bit. I suspect that the bit is a �� shank, �� dovetail bit and probably a 7 degree angle, but no confirmation. One of the model numbers may be HSS and the other carbide. The manual does say that all bits ought to have the shaft fit �� into the router so the shank has to be at least 1� long so it can fit into the bushing. Everybody makes a similar bit if that is the required dimension, but I need to translate #25505 or #26318 into dimensions. Does anyone out there have an old Sears Catalog that might identify those bits with a description?
Does any router bit company have a cross reference?
Re: Sears dovetail fixture and unknown bit
Re: Sears dovetail fixture and unknown bit *LINK*
del schisler
go to this web site. I check in all the time. Ask this question and i bet you will get the answare and the bit size's . Their is a fellow that goes by bobJ he will know .All you have to do is rejester. This is a router work shop that i have been with for year's. You can lean a lot from this site.
http://www.routerforums.com/
Not much help, but....
Hoa in Alameda
I found these tables on MLCS website. There are some references to Sears dovetail fixture:
Dovetail Router Bits
Straight Router Bits
I also found this as part of a review on Sears dovetail fixture:
"A long time(30 yr) buyer and user of craftsman woodworking tools, this jig as given to me as a gift. I found the most frustrating aspect of the jig is the total reliance on sears routers and bushings and router bits in order to make it work reasonably well. Most frustrating of all is that it is difficult to even find the 3 router bits that are required with this jig. The Sears stores don't carry the required stock numbers. The templates are made of plastic and you can easily nip the edge of one of the slots. That happens, but then it's hard to find a replacement template.
This is the first craftsman tool that I have owned that I wish I had another brand that is more durable and amenable to various routers and bits.
For 130 bucks I expected a lot more from this jig."
Good luck.
Larry in NW OHIO
Gary I have a 2004-05 tool catalog and they have them listed. I don`t know how much this is going to help, but hear is what they say. The 25415 is an "industrial 1/4 X1/4 straight" bit. The 25414 is an industrial 1/4 X9/16 dovetail bit and the other two are 1/4 X 1/2 with the318 being aHSS and the 505 is carbide. The first 1/4 being the shaft size. Hope this helps you somehow. Larry
Gary Smyth
Del,
Thanks for the lead. Found the Sears set although I'm glad I live close to five Sears stores within 30 miles. Only one had the set. It contains a 1/4" straight, a 1/2" 7 or 71/2 degree (it doesn't say and it was hard to judge by the old Price Cutter catalog picture I took with me) and a 9/16 dovetail. $26.00 in the store. I bought a separate matching 9/16 for $14 as I have multiples of the others. Thanks. You got me there all I have to do now is produce.
Yes, it did help. Thanks
Gary Smyth
