Veritas - Innovation in Tools
dovetail joint router bit question
Nat Robison
I have the PC 4212 router jig but I've misplaced the 7-degree bit that came with it. I can't easily/quickly find a 7-degree replacement but I can get an 8-degree easily. Will that be usable with my jig and bushings? Does it matter if I get a 1/4" shank or 1/2" shank?
Re: dovetail joint router bit question
roger lance
Nate....both Whiteside and Freud make dovetail bits that will probably replace the stock one you misplaced which was probably a Porter-Cable bit...Woodcraft sells both Whiteside and Freud....and also PC. My personal preference is to always use a 1/2" shank if possible. As to whether or not an 8 degree bit will work in the geometry of the dovetail templete you have....I can't say....that sounds like it falls under the heading of an experiment. Good luck.
Re: dovetail joint router bit question *LINK*
del schisler
i like 1/2" bits but sometime 1/4" are what you end up with go here and you can get the 7 degree bit Also their are lot's of places that have the 7 degree. Do a google serarch and you will get lot's of places. Stick with 7 degree bit. the dovetale will not be just right.The pin will not be right eather
http://www.thefind.com/hardware/info-7-degree-dovetail-router-bit
My thinking as well....
Nat Robison
I picked up an 8-degree bit today at HD but I'd rather not unwrap it if it's not going to work. Rockler sells a direct replacement but it's 30 mins. from my house. I'll probably end up going that route.
George Colonel's Workshop-Havertown PA
Good Afternoon Nate,
I also have the P+C 4212 jig. I also broke the P+C supplied bit. Its 7 degree replacvement was from Eagle America #134-0915. It cost $22.95. You can order on-line.
George
Moses Yoder
Re: My thinking as well....
Moses Yoder
You probably have a bushing on your router that fits in the dovetail template. The template is probably spaced at 1/2", making the inside of the bushing less than 1/2". So you probably can't use a 1/2" shank bit. The 8 degree versus 7 degree I am not sure on but it should work if your router bit can be set to the right depth.
roger lance
typically on PC templetes for 1/2" half blind dovetails , the standard bushing is the 5/8" bushing and the mechanical spacing is in 7/8" increments....but I don't have this specific PC jig (I've got an older Omnijig)....what I discovered was that the PC straight bit for through dovetails was alarmingly, dangerously short and I replaced it with a Freud 5/16" straight bit with a significantly longer 1/4" shank....sometimes you have to wonder if these companies try out their own products....so, don't worry about using different brands of bits....but I think you will be most successful if you maintain the same angel geometry.
Jerry Samsen
I also have that jig. I know that one of the criticisms of this jig was that it required proprietary PC bits (but replacements also made by Whiteside and others as noted).
i wouldn't try a generic dovetail bit. These things are finicky enough with the right bits.
My PC bits all have 1/2" shanks.
roger lance
Nat....if you can, see Popular Woodworking December 2007 p72-75 for an article by Don Means who did experiment with a PC 4112 and various router bits to create variable spaced dovetails on a fixed-space dovetail jig....might be of interest to you.
