simple picture frame: how to keep sides together?
ILYA Z
I'd like to experiment with making simple picture frames. The idea is to get some molding sold at Lowes or HD, cut four sides at 45 degrees and glue them together. What is the best way to keep the sides together as the glue dries? Is there a special tool for that or can I make a simple and cheap jig for this purpose?
Thanks much!
Re: simple picture frame: how to keep sides together?
Grant Wilkinson
I do the framing for two local artists, and have had excellent results from this set up from Lee Valley. It's flexible as to the size of the frames and it pulls everything together square every time. It may be a bit pricey for one offs, in which case, you may just want to make yourself a square jig and use wedges to make things tight until the glue dries.
http://www.leevalley.com/en/wood/page.aspx?p=31162&cat=1,43293
ILYA Z
Thanks Grant! It says "To increase clamping capacity to 44" square or 65" by 23" rectangle...". Does this mean that with the extension, you can make any frame whose sides ad up to 88"? If I want to make an even bigger frame, do I just need to buy extra extension sets?
Grant Wilkinson
Ilya. You can make frames as big as you like. The rod is simply 1/4" threaded rod, so you don't need to buy the LV extension kit. You can buy lengths of 1/4" threaded rod, some connector nuts and make them as long as you want. I framed a silk tapestry that is about 3' x 5' using my set, and it worked fine. With frames this big, be sure to put some weight on the pieces or you can pull them out of plane.
I've got a clamp set or two. They work. Though the Lee Valley set looks good.
To actually hold them together, I usually use feathers or splines. This gives a lot more gluing surface. I've got a spline jig for my table saw. I'm still working on one for my band saw. I've used my biscuit joiner to cut splines on some larger frame material.
Alex Grigoriev
I made a few frames from Lowes molding. After sawing, you may want to clean it with a plane for better glue holding. Also, those molding have stamped embellishments, which are difficult to sand.
steve mackay
I mark my 45s then grind 'em on the bench sander. As I do the next side I have them laying on a flat surface and check 'em with my square. Only grind one end at a time so I have plenty for adjustment. (No joints yet). When I'm happy with my corners and my squareness I glue it all together(no clamps). I have a flat melamine (sp) bench but wax paper will do in a pinch. Carpenter's glue is strong enough that, in the morning, I can flip the whole thing over. Now I take my Dremel and dig out 45 degree slots (across the joint), fill 'em with glue and insert tooth picks. (if its a large frame, dowel). The next morning spread some more glue over the splines (if its REALLY big lay on a peice of mesh drywall tape before). I NEVER have my glass cut before hand any more. I take the frame to my tame glass shop and let 'em cut it to fit. They're the pros not me. AND they get to pay for any mistakes/scrap. Start out with the flat molding. The crown is a bit tricky.
FredD
I have lost count of how many frames over rthe years I have made , but when I started doing Wainscot , I needed something much faster then glue and clamping.
If you want to try this , go to a Hobby shop , get Cyanoacrylate glue in the Gel form and a small bottle of Accelerator, glue one side of the joint , spritz the other side with Accelerator and form the joint , holding it for a few seconds , do one end to a side and then do the two ell's together.
Zap the joint with a couple of Pin nails and your done.
Exceptionally large frames would need additional reinforcement, but the Wainscot in our Bathroom has frames about 16 inches wide and four feet tall in the Wainscot with no problem assembling that size.
Small frames are even easier.
Before you glue a joint, practice holding the joint together until you can get the joint a close fit quickly , as the glue will not give more then a few seconds for adjustment.
FredD
Lee Schierer McKean, PA
I use a clamping jig similar to the Lee Valley design and it works very well.
One thing to remember when gluing is that you are essentially gluing end grain so apply glue evenly to both sides of the joint and use plenty of it. You want squeeze out. Clean up the squeeze out before it dries.
I find that I can cut perfect 45's with my Kreg miter gauge, but prior to that I used a home made jig that cuts both sides of the joint. The angle is set with a large accurate carpenter square. Cuting each half of the joint on each side assures a perfect fit.
Lee
Steve Strickland
Re: splines
Steve Strickland
Butt joints like you are contemplating are simple and fast. You can clamp the frame with a large rubber band or medical tubing an it works great.
However butt joints aren't very strong. For a better result you might want to use a spline joint. Before you miter cut the frame stock, cut a groove in the square end, say 1/8" wide, as deep as the miter will be. For wide frames you can use a bandsaw to get the full depth. Then insert a square piece of 1/8" stock and glue it all up. You can clamp the joints with plain old squeezers (I like the rubber tipped pistol types). This dramatically increases the glue area and reduces the ways the joint can be stressed.
To make the joint even stronger and eliminate all the directions of stress put a blind dowel in from the back so it doesn't show on the front. This type joint will not break at the glue joint - you must break the wood so it is as strong as it can be.
If you don't want the spline showing on the outer edges of the frame, you can put in a blind groove on a router and completely conceal the spline. This is really a biscuit joint without using the special tools. It's very strong and can again be strengthened further with blind dowels so that none of the joinery will show.
What pro framing shops use *LINK*
Robin Corell in Atascadero CA
The Stanley miter vise and its various clones is the workhorse for most any pro framing shop, and you really only need one. The nice thing about this style of clamp is it allows you to nail the corner while it is in the vise and it holds the work securely while doing so.
To make a frame with a miter vise you glue and clamp two legs and using a finish nail as a drill bit you drill and nail the corner from what will eventually become either the top or the bottom. Let it sit in the clamp for about 10 minutes and then repeat on the remaining two legs.
To join the two "L" shaped assemblies you support one corner on a bench horse and glue and clamp the other in the vise, drill and nail and let sit for a few minutes. Carefully unclamp and switch corners. There will be a little flexibility to allow you to apply glue to the remaining corner using a toothpick or whittled down Popsicle stick.
A second miter vise will speed up the process by allowing you to leave one pair clamped while glueing up the second pair, but is not nessesary to make a good frame.
A bench horse is just two boards joined together to form a �T� or �L�. The boards are the width of the working height of the miter vise and the horse is used on edge.
Robin
http://www.leevalley.com/en/wood/page.aspx?p=31164&cat=1,43293
