Off topic (golf cart battery prob)
Ed O'Neill
Batteries on my golf cart are producing white powder from electrolysis on the bottom of the batteries which is destroying the battery holder (steel). Any solutions as to what to do after removing and cleaning the batteries with baking soda ? How can I prevent this from happening again ? Thanks , Ed
Re: Off topic (golf cart battery prob)
Stuart Johnson
Clean it well then use the use the green and red felt things sold (or given) where ever batteries are sold. One trick I used before they were available was to smear both terminals with Vaseline. I don't know why but both methods seem to work.
Larry in NW OHIO
A bunch of years ago on our JD Yard Tractor this same thing happened. After cleaning it up I cut some old rubber tube and put that down and that seemed to do the trick. Larry
Ralph Lipeles
I don't know what size battery you have in the cart but hopefully it is an automobile type. If so, you can get a plastic tray to go under the battery. They are available at most boating shops. I have 2 in my aluminum boat and they do a great job for me.
Ralph Lipeles
del schisler
I belive you have 4 battery's at 6 volt each? doesn't matter . I would go to a battery place. They have a paint that they use in the holder that will fix or slow down the process.
All boats, babies and batteries leak
A. Kapocius
