Have a question? Ask Woody!
Looking For Help With Wind Chime
Tom Rex
I am making my first wind chime. I chose one that is approximately 10 pounds.
I strung it with 10 pound test fishing line but the metal pipes cut the string.
I am going to put grommets in the holes this time.
What do you use to string your wind chimes?
Would 50 pound fishing line work?
I�ve looked online but have been unsuccessful.
Thank you for any help you can give me,
T Rex
Re: Looking For Help With Wind Chime
Clint Searl
SpiderWire fish line
Clint Searl
Re: SpiderWire fish line
Tom Rex
Wher can I find this?
Went to BassPro.com and searched for it but did not get a hit?
How thick is this line?
Clint Searl
Clint Searl
Try Berkley braided nylon fish line.
Clint
Expensive, and not abrasion resistant
Joe Pack
SpiderWire is strong, but not very abrasion resistant. It is also extremely expensive compared to regular braided line.
Look for either a braided nylon line (commonly referred to as 'catfish' line), or, for a clear line, go with 40-50# Berkely Trilene Big Game which runs about $8 for 150 yards.
You can also look at nylon coated wire leader material (Cabela's, Bass Pro, etc.). It is a bit on the expensive side, but will last forever in your application. Be sure you look at the flexible stuff that you can actually tie knots in, not solid wire.
My hardware store sells stranded copper wire. It's held up for well over a decade.
paul in AZ
I have chimes given to me over 20 years ago that are suspended on what looks like reasonably heavy fishing line. No guess as to the pound test but it looks sturdy.
The holes in the tubes are rounded over so the line has not been cut through by rough edges in all this time. Grommets would do the same thing.
For real overkill security I suppose a solid or braided wire fishing leader would work.
With holes on opposing sides of a tube you could put a pin through and suspend the tube with a snap swivel like you see on fishing leaders.
Re: Picture-hanging wire
Al Stokka - Cambridge, Iowa
I used "mason's twine", woven nylon string about the same diameter of ordinary nylon string. Masons use it in her line blocks and use it to keeps courses straight and level. Because its woven it won't untwist. I happened to have some that was Camo-green. You can probably bet it any masonry supply store.
Round off the holes or use grommets.
Clint Searl
I guess I got lucky
Clint Searl
SpiderWire is still going strong after ten years on the chimes I made.
Clint
Moses Yoder
Re: I guess I got lucky
Moses Yoder
Makes sense, since spider wire is actually pretty abrasion resistant and there is very little abrasion on a wind chime. Personally I think the stuff should be outlawed for fishing, but using it for wind chimes sounds like a good idea.
Larry in NW OHIO
Moses I`m not a fisherperson, why should it be outlawed. Larry
Moses Yoder
Moses Yoder
I go salmon fishing in the fall, which are big fish. A big fish is a challenge to bring in, and you must use skill and cunning. I use 10 pound test P Line brand line. Amateurs will also go salmon fishing, and they think they need the strongest line possible. So they buy 80 pound test spiderwire and figure they can muscle in any fish they hook, instead of using brain power. What happens is their lure gets hung on a tree in the river, and the line is so strong they cannot break it off at the lure. So they cut it off on the bank, now you have 50 yards of 80 Lb. Test spider wire in the river. How long do you think that will be there before decaying? Now, whenever I drift close to the tree where the fish are my line gets wraped in their spider wire. A very frustrating day of fishing ensues, and there's absolutely nothing I can do about except mouth epithets at idiots under my breath.
Larry in NW OHIO
That`s kind of thought what it was, but didn`t know why. I can see your point, it doesn`t make any sense. Larry
Different results for fishing, maybe.
Joe Pack
Glad the SpiderWire is holding up for you chimes, Cliff. I put it on a baitcast reel for largemouth bass and was extremely pleased...until i fished an old boat dock w/metal legs. While the SW was strong as iron, I lost 2 good fish when the line rubbed up against the old, rusty legs...snapped right off where it was abraded. It seemed to not hold up to this kind of abrasion nearly as well as my good quality monofilament or copolymer. My all-time favorite line is Bagley's Excalibur copolymer...tough as iron, limp as a noodle. The only problem I have now is finding it. Not "sexy" like the super braids, but one fantastic line on spinning and baitcasting rods!
