OT - steering wheel removal
Carol Reed, Strawberry, AZ
I have a middle '80's John Deer garden tractor with a broken steering wheel. I bought a new steering wheel, but the old one is resisting every attempt to get it off. I have the parts and owner's manual. I removed the cross bolt.
Soaked in PB Blaster literally for weeks. Removed the plastic to get to metal. Used a three point gear puller with a breaker bar. I stopped at trying a pneumatic impact wrench. I have not heated the area - lots of plastic around that cannot be removed - like the dash.
There does not appear to be a spline, either in the drawings or in the new steering wheel.
Any thoughts, including cutting it off with an acetylene torch? I guess I could make some sort of heat shield. My brother has the welding gear, so I will have to load it up and take it over there.
One guy told me he had the same problem and wound up replacing the entire shaft. However, replacing a shaft that old could be problematic.
I guess we could cut if off horizontally and then weld an extension back on to hold the new wheel.
I am open to new ideas.
