Uses for hydraulic fluid ?
Yonak
I have 5 gallons of PB-2000 Tractor Hydraulic fluid. I don't have a tractor or anything with a hydraulic system. What can I use it for ?
Can I use it, instead of oil, in my lawn mower ? Can I put it in my compressor ? Can I use it to oil the gas in my 2-stroke engines ?
A little research has resulted, I think (some of the charts are a bit hard for me to decipher), in the following :
................................density.......viscosity index (@20�C / 68�F)
hydraulic fluid...........920kg/M�..............68
SAE30 oil.................890kg/M�.............200
SAE10 oil.................870kg/M�..............65
Maybe I can trade it to my local tractor repair shop for some saw chain sharpening.
Re: Uses for hydraulic fluid ?
Moses Yoder
Moses Yoder
I would go ahead and use it instead of oil in your car and lawnmower. Let me know if the engine freezes up and is ruined, I promise to feel bad about giving you bad advice.
Yonak
You seem sincere, Moses, so I'm going to use it in my brother-in-law's car. I'll let you know how it works out.
del schisler
It is hydraulic fluid and should be used as such...
Thomas S Stockton
tractor hydraulic fluid comes in a lot of different types I would give it to someone who can use it or recycle it. I can think of a couple of different types depending on whether or not it has wet brakes or dry is an older ford like an n series a newer ford, different John Deere specs for various tractors.
Tom
"Tire Black" . . .
steve mackay
I watched a guy use it as "Tire Black" once on his squad's vehicals. They WERE shinny & black . . . for a day or so. But then they cracked and fell apart. We didn't warn him as we didn't like him much anyway. He bought a set of tires that he didn't get to take home. Hydro fluid is good for one thing . . . hydro fluid.
Larry in NW OHIO
If you know any farmers, theymay take it. A friend of mine takes all I can give him, for one thing for starting brush fires. Also you might be able to take it to one of the 30 minute oil change places. Larry
Re: Uses for hydraulic fluid ?  or...
Carol Reed, Strawberry, AZ
...put it up on Craigs List.
Bar lube for chainsaws
Tom Dunlap
My front end loader got water in the hydraulic tank. After draining the fluid I kept it in five gallon buckets. It took several years to use up the fluid to lube the bars of my chainsaws. At the time I was running two crews so we used a LOT of oil. The fluid was the same as Ford power steering fluid at the time. I liked the smell and viscosity even in Minneapolis winters. The chains/bars didn't wear any more or less than when I went really cheap and used old crankcase oil. I stopped doing that because the smell was nasty. Now I use veggie oil, I think the base is canola/rapeseed with some sticking agents added. Now things smell like french fries...mmmm!
Send me some too...
John in NM
I'll give my boss a free oil change :D :D :D
Philip Duffy
Quenching fluid for your forging work. Its the best! Just keep the lid hands so when it catches on fire you can kill the flames before it takes off your eyebrows! Phil
Kneale Brownson
For disposal,
Kneale Brownson
In most states, anyone that sells oils has to have a tank for used oils that recyclers empty.
I like the idea of offering it up on Craigslist for folks who could use it properly.
John in NM
A friend of mine has a waste oil furnace. I used to bring him 40 gallons of gear oil, hydraulic oil, and misc. stuff every summer after maintenance at the telescope. You might look around for someone with such a furnace, or put an ad on CL or your local freecycle list.
I like the idea of using if for bar oil or quenching oil too, but of course you may not need those applications.
Yonak
Well, I could use it as bar oil but it just seems to me bar oil is so much stickier. Would it really protect my chain saw ? I hate to take it to be recycled. It's 5 gallons of unused oil. I think I'm going to take it my buddy across the road who has a machine shop and see if he can use it.
pete labelle
Put it on Craigslist under Farming & sell it. Someone will need it.
