Crown molding question
Randy Stukenberg
I have a situation where I need to run crown molding across the top of two upper cabinets. The cabinet on the right is about 5" higher than the one on the left, both faces are flush. I need to run the molding across the right cabinet, drop down 5", then continue across the left cabinet. How do I cut the two miters on that drop? It is a standard 2 3/4" crown purchased at one of the big box stores I think (customer provided).
Thanks!
-Randy
Re: Crown molding question
Moses Yoder
Moses Yoder
To look right the taller cabinet should be deeper than the short cabinet by whatever depth the crown is. The crown on the tall cabinet would be attached to the front and return back to the wall on both sides. The crown on the short cabinet would go across the face and die into the tall cabinet. If you are running the crown across the face of the tall cabinet then down to the short cabinet then across the face of the short cabinet it seems like they would be simple 45� miter joints, but you have to make sure you have enough room beside the door to attach the crown to the stile. I guess that's about all I can say with the info I have.
Concur
We had a similar problem when doing our kitchen, and solved the problem the way Moses suggests. My wife did not believe it would work, until she saw it.
If the cabinets are the same depth, and if you have enough room on the stiles of the higher cabinet, you could do a short mitered return of the crown on the lower cabinet, overlapping the face of the higher one.
But pictures would help us all see what the layout is like.
Re: Concur
Larry in NW OHIO
I`d like to see this when you get it done. Would thatbe possible. Larry
Randy Stukenberg
Unfortuantely, the cabinets are existing. The customer moved one higher to accomodate a new larger under cabinet microwave. I tried a 45 miter, but can't make it work right. The cabinets are all 12" deep and in the same plane. I agree, tho, that a deeper one to dead end one side into would be the best situation. I'll play with it and figure it out, I guess.
Re: Concur
Randy Stukenberg
That's a good idea. I may have to try that if I can't make the miters work out.
Not sure if you were directing that to Randy or me
but in case it was to me, here's a picture.
One of the things I've learned, living in a Victorian house - and thus being inspired to watch for molding details in other Victorian and period houses - is that the old guys learned, when they encountered problems, to be fairly open in acknowledging that the layout didn't fit the textbooks. Ideally, molding should die into the surface it meets; mitered returns, which run back to the wall, are actually one method of doing that (not visible in the photo above is that the upper crown runs back to the wall behind the cabinets). But when you can't do that, you just look for as graceful a method as possible to make the transition. For instance, when the molding is more prominent than the surface, it's not uncommon to find the end of the molding cut off at a truncated 45 degrees - running back to the surface of whatever it's butting up against. Little blocks of wood in corners, for the molding to butt up against, are another detail that you rarely find nowadays, but can be quite elegant.
Anyway, this kind of problem can consume more time for its size than much of the rest of the project; and certainly a lot of brain cells, coming up with an acceptable detail.
