We value your privacy.
Last week a posted about starting a blog to document the current project I am working on and to share up dates with my client. For anyone interested I often make models of my designs to present to clients and about three posts down is a pic of the model and a brief description of the design I am working on.
I have never been much of a writer but I am enjoying the blog. It may wear thin eventualy but it is a nice way to share my progress with my client and also give them a bit of insight as to exactly what they are paying for.
Another reason I hate routers is I can't hear the radio, even if I crank the volume up to 11.
Paraphrasing Spinal Tap. ...Look...see that, it's volume 11...Most only go to 10...Mine is better, it is 11..That's more isn't it.
Ok, full depth butterfly, dutchman, crack limiters. I understand how to start and I'm guessing that the band saw plays a part in making the actual butterfly, but in a 4/4, 6/4, 8/4 thick piece of wood. How do you adjust/mark the opposite side of the piece? Is the butterfly driven home or slid and glued? Do you fill your crack with color or leave it?
For butterflies that extend through the full thicknes of the stock I cut the butterfly on my band saw and then I sand a 1/2*-1* angle on the sides. I also make the butterfly out of thicker stock than the board I am trying stabilize. I cut the hole square with a jig saw and then when I clean up the hole with a chisel I add a bit of angle to the sides. I fine tune the fit by marking up the sides of the butterfly with a pencil or chalk and drop it in the hole, file the marks off and repeat. eventually the butterfly drops inplace with a nice tight fit .
On the butterflies on my blog I cut them with a template I made up and a bushing on my PC 310. The cypress is similar in hardness to poplar so with only 1/2* of angle on the sides I was able to just drive the butterflies home and let the harder wanut compress the cypress for a nice tight fit.
FYI 1* of angle on a 1" board is about 1/32".
I don't fill the cracks but that is just me. I want people to know exactly why those butterflies are there.
