THE WOODRAT IS BACK!
Inexpensive fix for air chucks/collets *LINK*
Dale Lenz
Dale Lenz
There has been past discussions about good air chucks or collets, female part at the end of the air hose that you put the male air device into, air nozzle, spray gun etc. When mine started to leak and kicked the compressor on a few times an hour I purchased a new collet/chuck. Did not throw my old c/c away. Tore into the device and found the rubber seal, called a washer. After much seaching went to a tire shop and had them order me a batch, 10 washers. Paid $8.50, thought, if that will fix 10 c/c over the years, good enought, even though I fiqured the tire shop doubled their money. The package from Milton had the part number & name: Milton Single head chuck washer 500-7. Seached google and found the part in several places, but the best place for most folks is O'Reillys auto store, belive O'reillys is nation wide(?). Anyway, the link below is to O'Reilly's. Suggest you print off the page and take to O'Reillys if you want the washer, as I tried O'Reilly several weeks ago and struck out, nobody knew want to call the "washer" that I was looking for. Your mileage may vary.
Air chuck washers
Re: Inexpensive fix for air chucks/collets *LINK*
Dale Lenz
PS
Dale Lenz
My collet is a no name brand, probably got it at Lowes(?). And yes, the washer fixed my collet/chuck from leaking, Yes!
Re: PS
This is for the Quick release coupling we put on the end of an air hose? I have wondered how they actually seal. I have never tried to disassemble one. How did you do it?
Re: PS
Larry in NW OHIO
Barry When you pull the ringback there is a wire ring, you take that off and everything comes off so watch the three balls so you don`t lose them. That should do it. Then just put it back together. Just be sure to watch how it cames apart. Good luck. Larry
Dale Lenz
Re: PS
Dale Lenz
On mine no wire ring, probably used vise-grips and Cresent wrench. Screws off, like the last post said pay attention how thing come apart.
Re: PS
Larry in NW OHIO
That`s right Dale, it comes off the bottom. I was talking about the top. I really have a lot of those brain farts as I get older. Yes Barry, you take the botton apart, it`s been awhile since I`ve taken one apart, and as Dale said they screw apart. I`m really sorry, I`m getting pretty bad, so when I say something, just take it with a very big grain of salt. Larry
