Home A/C followup
Home A/C followup
Home A/C followup
Nat Robison
I posted last week about my outside A/C unit not coming on when I turned it on for the first time last week. It worked fine thru last year.
Anyway, I got the thing apart today and found lots of empty nutshells in the area of the unit where all the wiring is. It also looks like the rodent may have gnawed at some of the wiring and took off the insulation. I isolated and wrapped whatever I could but the unit won't fire up. Also, the blade spins freely so it's not seized up.
Some of you posted some things to try electrically which are probably beyond my capabilities. My question is, let's say an animal gnawed some wiring, would that "trip" anything that could be reset? The breaker was not tripped and there's no carcass in the unit, so whatever was there wasn't killed by it. I had the same problem years ago and the technician just stripped off the damaged insulation, reconnected, and it worked fine.
I have a service tech coming out tomorrow but is there anything else I can easily check before then? I don't the requisite meters, equipment, or expertise to check all the electrical functions.
Re: Home A/C followup
Brian Aust
Can you post a picture of the area so we have a better idea of the damage?
FredD
Odds are the refrigerant is low.
The Tech will have the gauges and the correct pressure to if that's the problem.
It's really not a problem best addressed by home owner
Mine goes low on the two I have on the house about once every three years, the big one for the shop is in the shade all of the time and never has leaked.
FredD
Rancy Ceccotti
Had the same thing. Inside the controller panel where the rodent set up housekeeping, there is a set of contacts that make and break as needed. Take a fingernail file and lightly clean each side of the contact for any corrosion which may have formed from the junk they brought in. Then try it again.
Larry in NW OHIO
Rancy I know you have enough smarts to pull the power before you go inside of your unit, just a reminder. Good luck with it. Larry
Brian Aust
It could have shorted out the transformer, does it make any sound at all when you try to start it?
No sound, no nothing
Nat Robison
Kneale Brownson
Emory board or even a $1 bill is a better ...
Kneale Brownson
contact cleaner. A fingernail file may be too aggressive.
Re: Emory board or even a $1 bill is a better ...
FredD
Point files are available at Auto parts stores and are handy for other work as well.
FredD
