How to change planer gearbox oil
johannaj
johannaj
I have, thanks to this board, obtained the correct gearbox oil for my 20" Woodtek planer. But how in the world does one get it into the gearbox?! I tried using a pressure oil can - it just came right back out. I put some 1/4" tubing on a funnel - and that did not work- oil comes back out.
So can any of you who own a stationary planer with the gearbox oil hole on the side of the planer inconveniently behind the gear chain tell me how to get the oil into the planer? I'd lay it on its side if I could figure out how to ever get it upright again!
Re: How to change planer gearbox oil
Howard Norman
Changing the oil implies draining the oil that is currently in the planer. Have you done that? I am not familiar with that planer but there should be a drain plug near the bottom to drain the oil. As far as getting the fresh oil in I have always used a funnel with a flexible shaft to get the oil to where it needed to go.
Robin Corell in Atascadero CA
Are you sure that the gear box on your planer is supposed to have oil in it? The reason I ask is because I have a vintage 12" Parks planer and the gear box on it is supposed to be packed with grease. When I bought it it had been rebuilt and filled with oil, but I have a reprint of a 1949 manual and it clearly states that grease is to be used in the gearbox. This makes since because the small hole on the side is about right for a grease gun tip.
Robin
Alan in Little Washington (NC)
The gear box on my old 20" Delta RC-51 is packed with grease.
The gear box on my 15" Delta was filled with oil. It had a drain hole in the bottom and a filler hole about 2/3 of the way up the gearbox. Make sure it is drained and that there is not a second plug down in the the filler hole. Then use vinyl hose and a funnel if you need it (my bottle of oil had a nice long tip) to fill the gear box to the lip of the hole and reinstall the plug.
It would be nice if the gear boxes on these planers had sight glasses so you could tell if they were full. My old Max OSS and my compressor have them.
johannaj
johannaj
Draining it was very easy - the problem is that the tubing I have attached to a funnel does not seem to go in far enough - and that is the smallest tubing I have found - 1/4" OD.
johannaj
johannaj
Yes, it really does use gearbox oil. I have the manual, but for the life of me I just don't see how to get the oil in.
johannaj
johannaj
Thanks, Alan. I'll make sure there is not another internal plug, but I don't think so. I can put a 10d nail in quite a ways, but the tubing does not want to go in very far. That oil is really thick, and the 1/4" OD tubing has a small internal diameter, so I'm not sure I can go much smaller, even if I can find thinner tubing.
Where did you find oil with a long tip?
Howard Norman
How much oil does it take? Could you use one of the the pumper oil cans? I have one where the OD of the outlet, which is on a flexible shaft, is less than 1/8" diameter. I have 30 weight oil in my can. It might take a while but it might work.
Carol Reed, Strawberry, AZ
Perhaps you have an airlock. If your tube fits so tight in the hole, the air inside cannot get out to be replaced by the oil. Perhaps you can find a thin metal tube to fit into the hole and attach the plastic tubing to it. The metal tube would have to be smaller in OD to allow air to bypass the tube and allow the oil to flow. Hobby stores have thin metal tubing. My 2 cents. Good luck.
Try heating the oil too
Gary Camp, Bend Oregon
In addtion to using small diameter metal tube, insuring that there is an escape route for the air in the gearbox, try heating the oil in a pan of water.
glc
call Tech Service
Bill Tindall
All companies have technical service personnel to deal with these sorts of issues. It is rare that I don't find the answers to questions of this kind, unless I am dealing with an electronics or software issue.
del schisler
i belive what is happing is that their is air in the box. No oil mean's air in their. You will have to get a hose smaller the the opening so that the air will come out when oil goes in. Don't know the size of the oil hole. if big enough one hose inside of the other we will say the smaller one maybe you can push it inside but leve enough out so that it doesn't go down inside now pour the oin into the other hose . The smaller one let's the air out and the bigger one for the oil ??? The hole may not be big enough. But the air has to come out when oil goes in. good luck
Kneale Brownson
Oil bottles for oiling electric motors
Kneale Brownson
sometimes are available with a very small telescoping plastic tip.
And even then...
you may get an answer to your electronics/software issue - it's just that the response is incomprehensible.
Looking back on this thread, I had a last thought-
Get some muscle help, rest the planer on its side/back/front so the fill hole is facing up and add the oil. Put in the plug and stand it upright again.
I think most of these gear boxes are designed so the oil fills about 2/3 of it- when full the oil will run out the fill hole.
