Some Progress
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
The damn gout really put a kobash on progress lately. However I was able to give a spit coat of shellac and a wipe on coat of poly/naptha mix on the current items, a Wood magazine inspired Shaker bed, and two tilt top Shaker oval tables, also from Wood. I altered the plans signigicantly to suit my own feeble whims. (and to cover up mistakes)My #5 son Steve was just too dainty @ 275 pounds to haul out the furniture for a trial fit in the back yard. Accordingly, he got his Mom to help.
The bed is mostly solid cherry, accented with mahogany dyed QS sycamore at the tops of the head and foot boards, and the finials. The cherry was left out in strong sunlight for several days. The contrast between the inside bedrail and the balance of the item seems obvious. I do not artificially color cherry. I use a spit coat of shellac and wiping poly/naptha mix.
The dyes stcamore provides a very nice contrast in color and texture to the cherry, and remains in keeping with the Shaker simplicity of design and appearance.
The two oval tilt top tables are intended for use at home. One will act as a night table in the Guest Bedroom, and the other will be for occesional living room duty. Legs are sliding dovetails, shimmed into very tight joints, and reinforced by plugged screws into each turned spindle.
George
