SEALING ENDS OF GREEN WOOD
JERRY DRAPER
I am taking some white oak to a local saw mill. What is the best material for me to seal the end grain of the milled lumber. BTW I am paying $2.00/bf for the milling. Is that reasonable?
JERRY DRAPER
Gasp!!!!
Bill Tindall
That is an outrageous amount to pay. Check around more.
Studies have shown that end coating is only effective if it is done before any drying/checking occurs on the log ends. Personally I think it is a waste of time in any case unless one is drying very thick lumber. However, the ends of lumber stacks need to be protected from exposure to direct hot sun. If you live where it is hot already this is not the ideal time to be trying to dry oak. Do what you can to shade the pile.
Re: SEALING ENDS OF GREEN WOOD
pete labelle
There will nearly always be some checking. I've always painted my logs with some off color latex paint. Somewhat to reduce the evaporation of the water, but also to identify my logs.
$2.00 per board foot to mill ? $.25 - $.40 around SW Michigan. I can buy rough sawn green white oak for less than that.
Are your logs from your front yard, thus a risk of metal, therefore the sawyer is assuming to wreck a blade or two ?
Pete
Yonak
My sawyer charges 23� or $25.00 an hour for quarter sawn, and I pay for sharpening or a new blade if he hits a nail, but I've never had to pay for one.
WAY too much
Henry Higginbotham
I just paid $0.25/bf for mixed oak and pine, and the sawmill came to us. Would have been $0.20, but we wanted the oak quarter-sawn, and rather than get into counting it separately, just added a nickel to the price. This was in Alabama, and the sawyer had a well-used Woodmizer with hydraulic log loading and handling. Someone with a fancier mill and in a more expensive part of the country might charge a bit more, but not $2.00.
FredD
If that is true ,stay away from the Mill unless you are well heeled.
Like some of the guys said , it's like ten times to much , many small mills will sometimes cut it up for you for half of the lumber , but still........
Also , by all means paint the ends of the log before it is cut up with AnchorSeal or a thick Latex.
This is recommended by William T. Simpson who wrote the book on Kiln drying for the US Forrest service to keep end splits down as low as possible.
FredD
Near Richmond VA....
I paid $.25 BF to have some poplar sawed a few months ago. And the sawyer came, picked up the logs and returned the wood.
Not sure I would pay $2 a BF for tree run oak if THEY were supplying the logs.
Check with the WoodMizer site for a list of local sawyers. Lucas Mill and others may have a list also.
Robin Corell in Atascadero CA
Bill is sopt on about sealing needing to be done imidiatly for it to be effective. If the log has been sitting for a while you can cut off six inches and seal it but those six inches are what you would have lost if you hadn't sealed it.
I have used just about anything you could think to seal the ends with. In my experiance the most effective sealant is wood glue. I have part of a gallon that was a bit on the old side and a bit thick. it worked great.
I rarely seal the ends and I have been milling my own wood for over 15 years. if it is something really special I will seal it, and sometimes I seal crotch feathers to keep them from checking.
Robin
Thanks to all for the info.
JERRY DRAPER
Wow!!!!
Barbara Gill
I have run a sawmill for a long, long time and that is the highest charge I have ever heard of!
For hardwood I either charge .45 a sawn bd.ft. Or $45/hr. depending on several different factors. My mill is stationary so there are no set up or traveling charges.
Mike in Southern New Jersey
Hello my friend,
The days of getting bandmilling done for free are gone, and thats good because the sawyer deserves fair pay for his work. Having said that, the price you quoted is absurdly steep in my experience, if your sawyer is LOCAL. As a reference, my brother and I got about 700-750 BF of y. poplar sawn for an even $200. With bigger logs, like we had, that is easily less than a full days work for a medium sized mill.
OTOH, if the sawyer is traveling great distances to your location, then the price may be justified. Look at his TOTAL time, and include his round trip travel and wear and tear on his machine. It could be the reason for a high BF price.
Mike
Re: OUTRAGOUS PRICE
I believe the last time (about 2 years ago) that I purchased Kiln dried white oat (plain sawn) at the local mill I paid $2.70 bf - This was for THEIR wood, and I hand picked out the pieces I wanted. That was also for the full length 4/4 lumber, pieces less than 3 foot long were 50% less.
