Sander
Larry in NW OHIO
I have an old 6x48 belt sander that is an AMF. Can someone tell me how fast that should run. Without the sanding belt on the pulley runs around 2000RPM. Would that be about right. This thing has to be one of a kind. I tried to slow it down but the pulley on the drive shaft has a pulley shaft size of, if your sitting down put your seat belt on so you don`t fall off, the shaft size is 19/32. Yes a19/32" 0f an inch. I even checked the other end, it`s the same. Larry
