OT aluminum gutters
james runchey
I have to put up a new aluminum gutter and downspout on the back porch. Whats the easiest/best way to cut to length? Tablesaw? Snips?
OT aluminum gutters
james runchey
Re: OT aluminum gutters
steve mackay
Broke down and did my back last summer. Being a smart alec I tried a hack saw. Mess. Driven to see if I could make it worse I tried the jig saw. I did. Snips was the way to go. MUCH faster and cleaner. Then broke out the Ol' POP Rivet Tool. Actualy got a pretty professional result. Just for fun I smeared some sealant in the corners and joins but I'm not convinced it did much. Be carefull with those hanger mounts though . . . I got 'em up but I'm STILL not sure how !
hacksaw with very fine teeth.
Bill Tindall
Or at least that is how I have always cut it
Re: hacksaw with very fine teeth.
GalenVetterick
I used Bill's fine tooth hack saw method but used a stack of scrap lumber to fit the gutter profile and inverted gutter over it to give it support and guide a straight cut. You can use same support to back the trough and drill four corner holes for the downspout insert. Then cut opening with snips. You can use the cheap mans version and cut an x with a sharp chisel and bend the four tabs down to attach the spout.
Concur, with amendment and reservations
I worked briefly in sheet metal, and we used a 32 tooth per inch hacksaw blade on the bottom and front (especially on ogee gutter), but we'd often cut the straight back - the gutter without the lip that runs up onto the roof - with snips.
And this was with galvanized gutter, which is stiffer than the aluminum. I don't know how well aluminum will stand up to the hacksaw without distorting.
Easiest way? Let the Pros do it.....
If you are buying the thin gauge stuff they have at the Borgs, you can cut it with a utility knife. Score it repeatedly and it will break.
Did my own(LONG)
Larry in NW OHIO
James I redid our roof a couple of years ago and not sure, but I think I just used a snips, to cut it and In the corners I use a premade corner. I had steel shingled roofing put on, I wish I had done it sooner, and I did the gutters myself, at $1.00 a foot you can`t beat that. Also I wanted some kind of gutter guard on them while I was at it. I thought about how to do it while the time was coming. The best and cheapest way I could come up with, and Barry you may like this, I bought the plastic covers you can get at Menards, Home depot, and Lowes, for $1.00-$1.50 on sale for 4 footers with holes in them. They push under the shingles and snap on the gutters and you have it. But I had a really bad problem, my nice new expensive shingles did not have a way to push them under the shingles, now what to do. BUMMER. This took awhile of hard thinking, a couple hours later
it came to me take the covers and shorten them, but don`t cut them, but I needed to build a bending brake for plastic. So that is what I did. I put the first cover in and took my heat gun and started heating it and to my surprize it melted a pretty good size hole right where the gun was pointed, and rather quickly I must say. So it came to me don`t hold the gun in one place to long. After that it worked very well, I heated them and brought the brake over the plastic and took it on the roof and put it on and it fit pretty well, but what to do with the back, it just fell down. I played around with it a little and thought put a screw in the back to hold it where I wanted it. It`s on the third year and they are just as good as the first year and they don`t plug up at all. For around $100 for gutters and covers it turned out very well. Barry would be proud
Sorry this is so long. Larry
