200+ woodworking book reviews
12" Bandsaw query
12" Bandsaw query
Steve Strickland
12" Bandsaw query
Steve Strickland
What's a good 12" bandsaw for sawing stock up to 9" thick for 1/4" boards?
Re: 12" Bandsaw query
del schisler
their are a few good one's out their . Kind of depends if you have money? I own a delta 12" with riser kit. It is made in usa . I have had the saw around 20yrs. It is good. I use a resaw blade woodslicer .It can be got at highland wood working in alanta,ga good luck
There are none of which I am aware. Most 12" bandsaws have maybe a 4-5" resaw capacity.
If you get a 14" Delta with a riser kit, a 14" Grizzly with a riser kit or a 14" Rikon 10-325, you will have the 9" resaw capacity.
Dale Penkala
Hello Steve
I'm NOT an expert on the subject by any means, but I have the Grizzly 555x extrem model and I bought the 6" riser kit that would get you the 9" cut your looking for. I havne't put it in yet because I have had back surgury and can't disassemble the saw to put it in yet.
Before I bought the saw I did some research on them and found 2 websites that rated this saw quit highly. Here is the link to the 1st one:
http://www.toolcritic.com/analysis/12-14in-wood-cutting-bandsaws
The second site I found put this saw at #3 only being beat by the Laguna @ #1 and the Powermatic @ #2 if my memory serves me right. Problem is I can't remember that site.
Anyway I have only done a little resaw with the saw using the 3/8" blade the saw came with on 4" Maple and did a good job. I think if you had a good resaw blade and the 6" riser in it would do what your looking for.
Here is a pix of my bandsaw.
Hope this helps!
Dale
Mid-Michgan
Steve Strickland
Steve Strickland
Thanks everyone for all the great help. Saved me from making a costly error.
I selected the GO555x before I saw Dale's post. I think it'll do nicely.
Larry in NW OHIO
Steve As Del said the woodslicer is a very good blade, BUT I found a different place called Supercut Bandsaw Co. I bought 4 of there blades and tried them a little and I think they are better. I wish a few others would try them and see what they think, because you really can`t go by one person. A lot of their blades are carbide coated on the teeth. The website is "SupercutBandsaw" if you want to look them over. Larry
Chuck Lenz
You will also want a saw that has atleast a 1 hp or 1 1/4 hp motor.
del schisler
I talk to them about the blade? Price is inline with other resaw blade's. I don't need one right now but i will try one and see if their is a real difference. Alway's looking for something that is better or just as good. I do lot's of resawing and like to have a sharp blade. Sharp mean's good cut. Don't forget to set for blade drift also when changing blade's. del
