motor problem
Claudia
The motor on my elderly Makita planer (model 2040) has started to arc badly. The brushes are fine. Any suggestions as to what the problem might be? My knowledge of motors is pretty minimal!
motor problem
Claudia
Re: motor problem
Larry in NW OHIO
Claudia The first thing to come to mind is your brushes. They should be under a plastic screw on each side of the planer. These plastic cap unscrew counterclockwise mostly and under them are usually a brass color cap and then a spring. You just pull them out, I use a twizzers mostly, if they don1t fall out. Look at them, if you can see a wire on the bottom of them they are wore out, or if they are shortlike a 1/4" they are wore out. You can buy them at a place where they sell that product. Someone else will chime in here and tell you more. Good Luck. Larry
Re: motor problem
Phil Joines
If the brushes are ok check the spring tension. You could also have grooving or a build up of carbon on the commutator where the brushes ride. If it grooved you may need a motor shop if there's one near you or new motor. If it's just carbon a pencil eraser will remove the film. Also check the height of the insulation between the segments of the commutator. It should be below the surface of the brass.
Re: motor problem
Galen Vetterick
I agree with the others about potential checks. If it has arced much at all not sure how the brushes could be fine as you noted. They would at least show signs of smoke from flash and maybe a little rough. The brushes can bounce from low spring tension once they wear down causing the arcing.
Worst case might be a short in one of the windings to another or even a bridge on commutator from copper smear due to wear.
You just about need new brushes to compare unless your parts list actually list a size and length to check to.
Get it fixed as it will only get worse and cost more to replace.
Re: motor problem
Claudia
Thanks for the suggestions. Sounds like it is going to take a trip to a motor repair shop
