The Best Small Chainsaw
Scott Greaves in Blackfoot Idaho
I have two chainsaws I have been using, a Stihl 036 Pro, and an old, small Homelite saw my Wife bought for me about ten years ago. I started having problems with the Homelite last year, meaning it died, and I had my Nephew do a repair job on it over the winter. I ran it for about an hour the other day, and now it is dead again. I find I use the smaller saw more than the bigger one, and would like to get a really good small saw to replace it. I need suggestions. My biggest criteria is that it be well built and easy to start. I wore myself out yesterday trying to start either of my two saws, and never got any of the work done. Thanks!
Scott.
P.S.: Retirement is good! ;-)
Re: The Best Small Chainsaw
R. Payne
I have an Echo arborist saw that hasn't given me any problem in the 8 or 10 years I've had it.
ron
Ken Oakley-Sunny St. Cloud, Fla
I have a Stihl 16",( can't remember model #) ,and a Husgvarna 24". Wish the Stihl was a Husky. Great saws.
Stephen kirk
I've had a Stihl Miniboss for several years now. It's my go to saw. I've done nothing more than replace spark plug and filters. Usually starts on 5-6 pulls. And yeah, I routinely cut stuff over it's 14" bar and it never complains.
PaulSV
I was doing some yardwork on my father in law's house, and his gas powered chain saw wouldn't start, due to a rotted gas line. He had an old electric one in his shed, which I kind of scoffed at, but it actually worked quite well. I took down and cut up a 16 inch tree with it. If you just need a small saw, you could do worse. Just have to flip a switch to start it. That said, I've never had a problem starting my Stihl 18" saw.
Don Orr
Good suggestion for the Arborist saw above. Echo is a popular brand. They are designed to be used by tree climbers up in the trees for pruning, etc. Light weight, easy to start, reliable and can be operated one-handed if needed (carefully). Go with a trusted name.
I have a couple of old Homelites and can't kill them-and I've tried. :D
Had my Stihl 023 [16"] for 20 years, and while finicky to start the first time, it just keeps cutting. Had to replace all the fuel lines and sprocket a couple of times, but I grind my one chains and keep the bar dressed. Big saw is a 372x28" Husky which ain't no small saw. If it come to replacing the Stihl, I'll do so with an MS260-pro with an 18" bar. Great machine.
Clint Searl
Stihl FarmBoss
Clint Searl
Another vote for Echo
Henry Higginbotham
If cuss-free starting is what's important to you, I'd recommend Echo. I have a small Echo (Model something-3000). If it's been used in the last two or three days, it starts on the first pull. If it's been sitting up for a year or so with last year's gas in it (yeah, I know), then it takes three pulls.
Thomas S Stockton
Love my stihl ms250 use it more than my 039. we also have a small husqavarna that if you don't follow the exact starting procedure is a pain to get going.
Tom
David Barnett
My 'indoor' chainsaw...
David Barnett
...is the little Stihl (aptly-named) limbing saw. The sound of that starting behind the front door is even more effective than pumping the Remington 870.
  LOL
Dan Donaldson
Scott Greaves
Thanks everybody!
I see familiar names, but I hadn't thought of Echo. I took the Stihl in for a spring service yesterday, and the place sold Echo trimmers and such, but not chainsaws. They carried another off-brand. So I'll keep looking. I really am interested in easy-starting.
Scott.
Starting a Stihl
Pat Evans
I have an old 029 that only gets rare use. However it starts pretty well even on stale gas. I just give it a couple of pulls with the switch off, then switch on to choke and it usually fires right up on the first or second pull.
Re: Starting a NEWER Stihl
Gary Camp, Bend, Oregon
Is not so forgiving. If you don't follow the procedure exactly you end up flooding the engine. I love the way my saw cuts and handles but man it can be a pain to start. My saw is a 4 year old MS 360, I doubt that any of the newer saws start much easier, due to air polution control constraints, or so the local saw shop tells me.
glc
Larry in NW OHIO
Scott I`ve had an Echo for the last 40 years and would not buy anything different. I still have a top handle 12" all those years and never had any trouble with it and it would always start after a winter of setting some years. It would be had to start the first time then the rest of the year the first or second pull it was running. Last year I was in the market for a 16" and thought I`d try a Sthil but my dealer told me to stay away from the small Sthils, that they bwere cheaply made but not the bigger one. So I bought an Echo, he also sells Sthil. Larry
Jim DeLaney, Austintown, Ohio
For the newer ones: Lock the throttle open; Put the choke full on; Pull till it 'coughs,' then move the choke to half; It ought to start on the next pull. Move the choke to open afer about fifteen seconds of run time.
Learned that from a Stihl factory tech, and it's never failed me. All three of my Stihls start reliably that way.
My Husqvarna 141
mdclor
always starts easily for me. FWIW
Gary Camp, Bend Oregon
Yes, that is the sequence that works. It usually takes 4-5 pulls to get the "cough" you darn sure don't want miss setting the choke to half after the first cough, though. A second cough = flooded engine. My old 033E, Full choke, full throttle, second pull, engine started, then adjust the choke, sure miss that saw, just couldn't get parts for it any longer.
glc
Stihl 260
bill tindall
I bought one for son in law and it saws about as fast as my 036, while being much lighter. Start as others have recommended. I have used it a fair amount and it would be the saw I bought if I was to replace the 036.
I recently bought a Husky 445 for a job where I needed to pack a saw to a remote location.. It starts easier than Stihl. I got it reconditioned off ebay for $250. I is not a toy saw, but obviously not as zippy as the 036 in big hardwood timber.
NO one handed use!!!
Tom Dunlap
NO! NO! NO!
I make my living, and have since about 1973, as and arborist.
One-handing saws is one of the most dangerous things any chainsaw user can do.
Chainsaws have been described as one of the most constructive and destructive tools that humans have ever made.
Top handled saws still have two handles on them...one for each hand.
NEVER one-hand a saw. Too many pros still do even though the manufacturers, OSHA and ANSI Z133 standards and regulations...as well as all training manuals, do NOT allow the practice.
Service/PPE/electric
Tom Dunlap
The best saw is the one that can be serviced by a local shop. Husky, Stihl and Echo lead the pack. Find out where warranty work is done. Talk with arborists or loggers in your area. They depend on their saws for their living and won't tolerate waiting for a repair shop to order repair parts or a long back-log.
Spend money on a helmet with a face shield, safety glasses too because the face shield doesn't meet ANSI Z87.1 standards. Hearing protection, either earmuffs or foam plugs...say, What?!?! :)
An electric saw is a consideration for occasional use too. No fuel issues either. Be careful of the brand just like a gasser. Watch Craigslist or ebay.
Keep TWO hands on the saw and your left thumb wrapped around the tubular handle.
Scott Greaves
First, I wanted to thank everybody who responded to my inquiry. Your discussion was priceless in making my decision. I am so lucky to have friends like you to call upon for advice!
I decided on the Echo 360T with 16" bar. It's a top handle model. I had to special order it from the local dealer, but it should be in by this Friday.
I have a lot of downed trees at my cabin, knocked over by the snow sliding off my roof, that I need to limb and cut up. This saw should do me well. Thanks!
Scott.
