Have a question? Ask Woody!
A gluing problem and its solution
Bill Tindall
I am gluing the skirt onto the bottom of a chest of drawers. The top corner of the miter must precisely align with the bottom of the vertical part. The third element, the applied foot is fitted in the remainder after the skirt is attached. When glue and clamps are applied there is the likely hood that the skirt will skid out of alignment.
The solution:
A few brads are driven into the cabinet and the heads cut off. One such brad is at the point of the pencil. Glue is applied and the skirt is pressed into place. The pointed brads easily penetrate the skirt board and keep it from skidding. Then clamps are applied.
Re: A gluing problem and its solution
Larry in NW OHIO
Bill Just from the little bit of what I can see from the pic, I can see that is going to be a beautiful cabinent. I wish I could do 1/4 of what you are doing with that cabinent. But one question, the design on your skirt, I guess that is what you are refereing to as the skirt, do you carve that by hand or some other way? Thank you Larry
Clint Searl
Clint Searl
Old-timers used a few grains of sand.
Clint
On caving the skirt...easy
Bill Tindall
I did what many cabinet makers did in times past . I farmed the carving out to a professional carver, May May. I am missing the carving gene.
