Help! Wood Central is broken....
The posts I have read have stopped turning green and the cherries are erratic. Sometimes they go away and sometimes they persist. I tried leaving completely and coming back, but it did not help. What else can I do?
Re: Help! Wood Central is broken....
Dave's Not Here
Did you upgrade to the latest IE release? If you did, click on Tools and find Capability View in the drop down window. Click on that and hopefully it will fix what you're experiencing.
I Need Another Spelling Lesson
Dave's Not Here
That's Compatability View............
Did not change anything....
that I know of. This started yesterday. As far as I know I am doing exactly what I have been doing for a long time. I am using EI but its the same as it was before.
Firefox...
Chuck in Mtl.
try Firefox....much better than IE.
Wood Central is NOT broken....
... or changed since your last visit.
Hi Barry,
Your browser is responsible for remembering which pages you've visited, so if the text doesn't turn green after you've read a message, it is a function of the browser, and some browsers might display visited page links differently. We have no control over that here. I do heartily recommend Firefox or Chrome over Internet Explorer, though, as IE is notoriously non-compliant with a lot of web code.
As for the cherries symbols being erratic, I don't know what that means, but the cherry information is contained in your cookie. You have a different cookie for each messageboard, as well as one for each browser and each computer you are using. If you change computers or browsers, or delete your cookies, the browser you're using will not remember changes made to a different cookie on another browser or computer.
I don't know if any of this pertains or helps; hope so.
No offence intended....
I simply don't have a clue as to why this would start happening. I have not changed anything since I started using IE or Wood Central. I have no idea where these things occur or why. I don't want to know how IE works, I just want to come to Wood Central and enjoy the visit and make a contribution if I can, both financial and by sharing what I have learned.
So, Does any one have a practical suggestion. Other than switching Browsers? Should I reboot? (that's the only thing I know to do when the computer gets a case of the @$$.) Delete the cookies? Can somebody tell me how? Thanks for any help.
Re: No offence intended....
Joanne in Point Pleasant, PA
Perhaps in a recent Windows Update, IE was updated to a newer version and that version is less compliant with web code, as Ellis suggests. Firefox and Chrome are both free, run faster, and have fewer problems than IE (in my experience). Why not try one of them?
Jesse Cloud
"The posts I have read have stopped turning green and the cherries are erratic. Sometimes they go away and sometimes they persist."
Dude - that's exactly what happened to me for most of the sixties. Any funny tasting brownies in the cookie jar ;)
Dan Donaldson
The best thing to do is to delete all of your WC cookies and reestablish them. You say that you did nothing, but it is just past the Microsoft tuesday updates. If you have automatic updates enabled, it may well have made browser or other changes. My daughter's webcam in her laptop just suddenly stopped working after the updates. I reinstalled the drivers and it came back fine.
Just out of curiosity, what is your objection to changing browsers? IE is notorious for being non-compliant with web standards and for having a multitude of security holes. As mentioned, chrome or firefox are faster, more compliant, less memory usage, and safer than IE. What's not to like?
(before I get pounced on, the other browsers can have security issues also, just not near as many so far and it is possible to protect yourself as long as you are religious about security and stay up on the latest security releases, even with IE)
PS
Dan Donaldson
If you do decide to try another browser, you can install all of them simultaneously and use whichever one you want at any time. Just be aware that the cookies are browser specific, so if you read a site, then change browsers, it will not know you have read them.
Bill Blasic
Re: PS
Bill Blasic
I use Firefox and last week on Tuesday and Wednesday I lost the cherries only in the turning section, back to normal from Thursday on. Must be Gremlins!
Bill
del schisler
what version of IE ? it should be version 8 . Do you do the scan disk and defreg from safe mode? If not do it from safe mode. It you had no problum's before than it should work again. I had a problum a while back and went to firefox that worked. But than i up graded to IE version 8 and that fixed my problum ? Mite not be your's tho. Maybe go in and do a up grade of the IE 8 again and see if that fix's anything. good luck del
Same Thing Here, Barry
David Yoho
I'm a little late to this party but I experienced the same thing here this past weekend. I had to reboot anyway for another reason and all is working like it should again. I am using IE-7 because 8 sucked and 9 won't run with XP.
If your computer is newer and running Win-7, you can install IE-9 if you don't already have it. I've heard some very good things about this version and it's supposed to be HTML-5 compliant as well.
Dan, I guess I am just a stick in the mud. A perfect Microsoft customer. Once an IE user, always and IE user. I do it with everything though. My mentality is that I can make what I have work. (Check out my post on repairing railings. I was horrified at the idea of trashing them and getting new ones.)
I am about to go crazy and down load Chrome. I had it before and will Ty it again. Very reassuring that I can have both. Does Chrome import your favorites list?
Dan, An additional Question....
I was right at the point of clicking Download on the site for Chrome when it dawned on me that I use MicroSoft Security. Will that protect Chrome? I used to have Norton and Mcafee and hated both of them. Comcast provided McAfee and I jumped at the chance to get away from Norton. Then they changed to Norton, so I went to MS Security Essentials.
Just as I was unaware that it Was IE keeping up with what I rad, I am unsure if MS will protect Chrome. (I am running Windows 7 but don't know which IE it is.) I just rebooted and it did not start tracking again.
Yes, as far as I know
Dan Donaldson
My daughter uses the microsoft security on her laptop with chrome and has not had any problem. On this one, I cannot speak from direct experience as I don't run Windows, nor IE.
Dan Donaldson
I believe chrome will import your favorites list while you are installing it if you let it.
